Re: Xtext 2.9 maven + generate artifacts [message #1723294 is a reply to message #1723292] |
Sat, 13 February 2016 11:48   |
p.s. here is the output of a mvn dependeny:tree on the mydsl project
[INFO] org.xtext.example.mydsl1:org.xtext.example.mydsl1:jar:1.0.0-SNAPSHOT
[INFO] +- org.eclipse.xtext:org.eclipse.xtext.junit4:jar:2.9.1:test
[INFO] | \- junit:junit:jar:4.8.1:test
[INFO] +- org.eclipse.xtext:org.eclipse.xtext.xbase.junit:jar:2.9.1:test
[INFO] +- org.eclipse.xtext:org.eclipse.xtext:jar:2.9.1:compile
[INFO] | +- org.eclipse.xtext:org.eclipse.xtext.util:jar:2.9.1:compile (version selected from constraint [2.9.1,2.9.1])
[INFO] | +- org.eclipse.xtend:org.eclipse.xtend.lib:jar:2.9.1:compile (version selected from constraint [2.9.1,2.9.1])
[INFO] | | \- org.eclipse.xtend:org.eclipse.xtend.lib.macro:jar:2.9.1:compile
[INFO] | +- com.google.guava:guava:jar:14.0.1:compile (version selected from constraint [10.0.1,14.0.1])
[INFO] | +- com.google.inject:guice:jar:3.0:compile
[INFO] | | +- javax.inject:javax.inject:jar:1:compile
[INFO] | | \- aopalliance:aopalliance:jar:1.0:compile
[INFO] | +- org.eclipse.emf:org.eclipse.emf.ecore:jar:2.11.1-v20150805-0538:compile (version selected from constraint (2.8,3.0))
[INFO] | +- org.eclipse.emf:org.eclipse.emf.common:jar:2.11.0-v20150805-0538:compile (version selected from constraint (2.8,3.0))
[INFO] | +- org.eclipse.emf:org.eclipse.emf.ecore.xmi:jar:2.11.1-v20150805-0538:compile (version selected from constraint (2.8,3.0))
[INFO] | +- log4j:log4j:jar:1.2.16:compile
[INFO] | +- org.antlr:antlr-runtime:jar:3.2:compile (version selected from constraint [3.2,3.2])
[INFO] | \- org.eclipse.equinox:org.eclipse.equinox.common:jar:3.6.0:compile
[INFO] +- org.eclipse.xtext:org.eclipse.xtext.xbase:jar:2.9.1:compile
[INFO] | +- org.eclipse.xtext:org.eclipse.xtext.xbase.lib:jar:2.9.1:compile (version selected from constraint [2.9.1,2.9.1])
[INFO] | \- org.eclipse.xtext:org.eclipse.xtext.common.types:jar:2.9.1:compile (version selected from constraint [2.9.1,2.9.1])
[INFO] | +- org.eclipse.emf:org.eclipse.emf.codegen:jar:2.11.0-v20150806-0404:runtime (version selected from constraint (2.8,3.0))
[INFO] | \- org.ow2.asm:asm-commons:jar:5.0.1:compile
[INFO] | \- org.ow2.asm:asm-tree:jar:5.0.1:compile
[INFO] | \- org.ow2.asm:asm:jar:5.0.1:compile
[INFO] +- org.eclipse.xtext:org.eclipse.xtext.xtext:jar:2.9.1:compile
[INFO] | +- org.eclipse.xtext:org.eclipse.xtext.generator:jar:2.9.1:compile (version selected from constraint [2.9.1,2.9.1])
[INFO] | +- org.eclipse.xtext:org.eclipse.xtext.ecore:jar:2.9.1:compile (version selected from constraint [2.9.1,2.9.1])
[INFO] | +- org.eclipse.emf:org.eclipse.emf.codegen.ecore:jar:2.11.0-v20150806-0404:compile (version selected from constraint (2.8,3.0))
[INFO] | +- org.eclipse.emf:org.eclipse.emf.mwe2.runtime:jar:2.8.3:compile
[INFO] | +- org.eclipse.emf:org.eclipse.emf.mwe2.lib:jar:2.8.3:compile
[INFO] | +- org.eclipse.emf:org.eclipse.emf.mwe2.language:jar:2.8.3:compile
[INFO] | +- org.eclipse.emf:org.eclipse.emf.mwe2.launch:jar:2.8.3:compile
[INFO] | +- org.eclipse.emf:org.eclipse.emf.mwe.core:jar:1.3.13:compile
[INFO] | +- org.eclipse.emf:org.eclipse.emf.mwe.utils:jar:1.3.13:compile
[INFO] | +- org.eclipse.xpand:org.eclipse.xpand:jar:2.0.0:compile
[INFO] | +- org.eclipse.xpand:org.eclipse.xtend:jar:2.0.0:compile
[INFO] | +- org.eclipse.xpand:org.eclipse.xtend.typesystem.emf:jar:2.0.0:compile
[INFO] | +- com.ibm.icu:icu4j:jar:52.1:compile
[INFO] | +- commons-cli:commons-cli:jar:1.2:compile
[INFO] | +- commons-logging:commons-logging:jar:1.1.3:compile
[INFO] | \- org.eclipse.xtext:xtext-antlr-generator:jar:2.1.1:compile
[INFO] | \- org.xtext:antlr-generator:jar:3.2.1:compile
[INFO] \- org.eclipse.xtext:org.eclipse.xtext.xtext.generator:jar:2.9.1:compile
FUDForum. Page generated in 0.05346 seconds
