Re: Non documented dependency for OCLinEcore [message #1723256 is a reply to message #1723234] |
Fri, 12 February 2016 13:33   |
[PivotStandalone.html was not updated for Mars, which was confusing, but
I think that oversight has now vanished from what is visible.]
You certainly should not need to have a *.ui dependency. It should be
sufficient to invoke |EssentialOCLStandaloneSetup.doSetup()|
as mentioned in the help. Have you invoked it?
If you are packaging for an update site, you may prefer to spare your
users the parsng cost of OCL by parsing the OCL while building using
CGed rather than delegated OCL execution. CGed execution is pure Java
and so has few and obvious dependencies; no need for any Xtext plugin.
Ed Willink
On 12/02/2016 17:26, Elie Richa wrote:
> Hello,
> I'm trying to embed OCL invariants and OCL definitions for derived
> attributes in my metamodel. I encountered some issues with plugin
> dependencies but managed to fix them. I'm writing this post to explain
> what I did and maybe point out a bug/confusion in the OCL related
> plugin dependencies.
> I used the OCLinEcore editor to embed the right EAnnotations at the
> right place in my metamodel. I generated my metamodel classes with a
> GenModel and got seemless [Live] validation with the standard
> reflective model editor.
> However when I packaged and provided my metamodel plugin through an
> update site, things did not work out of the box. OCL validation did
> not work because the Pivot OCL evaluation delegate was not registered.
> Going back to the documentation, I found
> http://help.eclipse.org/mars/topic/org.eclipse.ocl.doc/help/PivotStandalone.html?cp=53_6_2_1#XtextParsers
> that I needed the following dependencies in my plugin:
> org.eclipse.ocl.pivot (for the execution delegate)
> org.eclipse.ocl.xtext.completeocl (the rest of the plugins are for
> parsing the OCL expressions embedded in the metamodel)
> org.eclipse.ocl.xtext.oclinecore
> org.eclipse.ocl.xtext.oclstdlib
> This helped, however now I had the following exception:
> org.eclipse.ocl.pivot.internal.delegate.OCLDelegateException: Failed
> to create Xtext resource for '_dFM5ANF4EeW2U5NQBGUb7g.essentialocl'
> at
> org.eclipse.ocl.pivot.internal.delegate.SettingBehavior.getQueryOrThrow(SettingBehavior.java:67)
> at
> org.eclipse.ocl.pivot.internal.delegate.OCLSettingDelegate.get(OCLSettingDelegate.java:109)
> at
> org.eclipse.ocl.pivot.internal.delegate.OCLSettingDelegate$Changeable.get(OCLSettingDelegate.java:55)
> at
> org.eclipse.emf.ecore.util.BasicSettingDelegate$Stateless.dynamicGet(BasicSettingDelegate.java:185)
> Caused by: org.eclipse.ocl.pivot.utilities.ParserException: Failed to
> at
> org.eclipse.ocl.pivot.internal.context.AbstractParserContext.createBaseResource(AbstractParserContext.java:72)
> at
> org.eclipse.ocl.pivot.internal.context.AbstractParserContext.parse(AbstractParserContext.java:150)
> at
> org.eclipse.ocl.pivot.internal.manager.PivotMetamodelManager.parseSpecification(PivotMetamodelManager.java:2148)
> at
> org.eclipse.ocl.pivot.internal.delegate.SettingBehavior.getQueryOrThrow(SettingBehavior.java:65)
> ... 26 more
> This happened when the validation code was trying to parse the OCL
> expression corresponding to a derived attribute. By debugging I found
> that around AbstractParserContext.java:72 the code tries to create an
> XText resource based on the URI extension 'essentialocl', however the
> extension was not registered. So I had to find the plugin that should
> register that extension.
> Digging further I found that the plugin that does that is
> org.eclipse.ocl.xtext.essentialocl.ui because its plugin.xml has the
> following extension point:
> <extension point="org.eclipse.xtext.extension_resourceServiceProvider">
> <resourceServiceProvider
> class="org.eclipse.ocl.xtext.essentialocl.ui.EssentialOCLExecutableExtensionFactory:org.eclipse.xtext.ui.resource.IResourceUIServiceProvider"
> uriExtension="essentialocl">
> </resourceServiceProvider>
> </extension>
> I added this dependency to my plugin which made everything work out of
> the box: the simple installation of my metamodel plugin now triggers
> the installation of all OCL dependencies, including
> What I find weird is that:
> 1. The
> does not mention org.eclipse.ocl.xtext.essentialocl.ui as a
> dependency for parsing OCL expressions.
> 2. I find it weird to include a *.ui dependency even though I'm not
> developing any UI plugins.
> Does that qualify as a bug? :)
> Could the registration of the 'essentialocl' URI extension be done in
> a more appropriate plugin?
> Thanks.
> Elie
Re: Non documented dependency for OCLinEcore [message #1723259 is a reply to message #1723256] |
Fri, 12 February 2016 14:03   |
Your description confused me. PivotStandalone.html describes standalone
usage.
Sentence 1: "If you use Eclipse OCL within Eclipse, you should find that
the appropriate registrations are provided for you automatically by the
plugin registration mechanisms."
So if you choose to install an OCL subset, it is your problem. OCL users
are expected to install the OCL distribution, and this includes the UI
which is where Xtext provides its supported registration.
That said, you may still find CGed generation more streamlined.
Ed Willink
On 12/02/2016 18:33, Ed Willink wrote:
> Hi
> but I think that oversight has now vanished from what is visible.]
> Regards
> Ed Willink
>> Hello,
>> explain what I did and maybe point out a bug/confusion in the OCL
>> related plugin dependencies.
>> registered. Going back to the documentation, I found
>> for parsing the OCL expressions embedded in the metamodel)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 26 more
>> </extension>
>> of the box: the simple installation of my metamodel plugin now
>> triggers the installation of all OCL dependencies, including
>> 1. The
>> Thanks.
>> Elie
Re: Non documented dependency for OCLinEcore [message #1723439 is a reply to message #1723437] |
Mon, 15 February 2016 12:19  |
CG is not the default. It's still 'experimental' and I keep improving
it. There is a tutorial. It is used to generate the Java code from
Pivot.ocl that validates your OCL. It is increasingly used by the QVTd
project for generation of compiled transformation code. It is a true CG
with an intermediate model and optimizations and nominally 100% syntax
coverage, unlike some other OCL research CGs that inaccurately support a
Java-like OCL subset that is amenable to simple textual mapping.
The underlying CG API is relatively simple and stable from that point of
view, but it is nonetheless improving. Do not use the CG if you are
delivering code that you are not prepared to re-genmodel for each
Eclipse release.
Ed Willink
On 15/02/2016 16:48, Elie Richa wrote:
> Hi Ed,
> Thank you for the answers.
> On 12/02/16 20:03, Ed Willink wrote:
>> Hi
>> usage.
> Understood. I wanted to avoid asking users to install OCL, but in
> retrospect it's a pretty easy installation step so I might as well ask
> them to do it.
> I wasn't aware of the possibility of OCL->Java CG for metamodel
> invariants since it's not the default. I think it's also less
> advertised advertised than the default. I'll give it a try.
> Thanks!
FUDForum. Page generated in 0.05599 seconds
