UML Model Import [message #1723178] |
Fri, 12 February 2016 06:26  |
Is there any way to import an activity diagram inside SysML Block.
Activity is there in separate project to that of block.
Any help would be appreciated
Re: UML Model Import [message #1723209 is a reply to message #1723191] |
Fri, 12 February 2016 08:47   |
Quote:and set the classifier behavior of activity,, Is it Right?
Classifiers must own their Classifier Behavior, so this looks like a bad idea. Each Behavior (Activity) can have only one owner
If you want to reuse an Activity, you need to rely on CallBehavior actions: Create a new Activity in your Block, specify it as ClassifierBehavior, then create a CallBehaviorAction in this activity, and reference the imported Activity
HTH,
Camille
Re: UML Model Import [message #1723219 is a reply to message #1723209] |
Fri, 12 February 2016 09:51  |
I mean I Import an activity(by activity I mean to import the whole project file as there is no way to import one diagram from the project) in my model, then drag activity from the imported project inside the block and set this activity as block's classifier behavior, Now is t right or do I need o use call behavior action still??
FUDForum. Page generated in 0.03847 seconds
