Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] Custom control get parent of an eStructuralFeature(Custom control get parent of an eStructuralFeature)
[EMF Forms] Custom control get parent of an eStructuralFeature [message #1722675] Mon, 08 February 2016 03:55 Go to next message
Hi guys,
I have an Ecore model that has the following structure:
BoolEnum
-> TRUE
-> FALSE
BoolStringValue
value -> BoolEnum
DifferentType1
boolStringValue -> BoolStringValue
DifferentType2
In my new custom control I want to be able to render differently the value combobox (from BoolStringValue). But how can I know its parent, from where it comes from (DifferentType1/DifferentType2)?
This is the skeleton for isApplicable method:
.... isApplicable(){
if (eStructuralFeature.getName().equals("value") && eStructuralFeature.getEContainingClass() == (EClass) pack.getEClassifier("BoolStringValue") && (condition??) )
return 10;
And which SWT control renderer should apply here to create the control? Should I use a BooleanControlSWTRenderer?
Thank you very much,
S.
Re: [EMF Forms] Custom control get parent of an eStructuralFeature [message #1722785 is a reply to message #1722675] Tue, 09 February 2016 02:23 Go to previous messageGo to next message
you can access the domain model with:
viewModelContext.getDomainModel();
and then you can do any check you want, e.g. for a specific parent.
Best regards
Jonas
Am 08.02.2016 um 09:55 schrieb Teohari Simona:
> Hi guys,
> BoolEnum -> TRUE
> -> FALSE
> BoolStringValue
> value -> BoolEnum
> DifferentType1
> DifferentType2
> ... isApplicable(){
> return 10;
> S.
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms] Custom control get parent of an eStructuralFeature [message #1722945 is a reply to message #1722785] Wed, 10 February 2016 07:32 Go to previous messageGo to next message
Sorry, but this did not worked. From what I noticed, the viewModelContext.getDomainModel() gives information about the view model, but I can have multiple view models with different domain model references that are like this:
ViewModel1
X -> ... -> something -> BoolStringValueType -> value
ViewModel2
Y -> something -> BoolStringValueType -> value
ViewModel3
Z-> ... -> .... -> something -> BoolStringValueType -> value
I'm always interested in the class that contains a reference to this BoolStringValueType. (called "something" in the previous example)
Thank you,
S.
Re: [EMF Forms] Custom control get parent of an eStructuralFeature [message #1723063 is a reply to message #1722945] Thu, 11 February 2016 05:51 Go to previous messageGo to next message
what makes you believe that viewModelContext.getDomainModel() returns
something about the view model? Have you debugged that? What does it return?
best regards
Jonas
Am 10.02.2016 um 13:32 schrieb Teohari Simona:
> ViewModel1
> ViewModel2
> ViewModel3
> Thank you,
> S.
Jonas Helming
Re: [EMF Forms] Custom control get parent of an eStructuralFeature [message #1723149 is a reply to message #1723063] Fri, 12 February 2016 02:52 Go to previous message
I am sorry about that Embarrassed, I found the eContents() and eAllContents() methods from the viewModelContext.getDomainModel(). I will use them.
Thank you,
S.
Previous Topic:[Teneo] Enable Full Use API of EntityManager
Next Topic:[EMF Forms] save changes?
Current Time: Fri Jul 18 21:54:48 EDT 2025
Powered by FUDForum. Page generated in 0.25000 seconds
