Home » Newcomers » Newcomers » An error has occurred. See the log file(An error has occurred. See the log file)
An error has occurred. See the log file [message #1722964] Wed, 10 February 2016 10:06 Go to next message
Hello everyone,
I'm a new eclipse user. I'm using opensuse tumbleweed 42.1 .
I installed eclipse Mars .
When I try to open eclipse, an error message appears.
What is the solution for my problem ?
  • Attachment: Untitled.png
    (Size: 9.50KB, Downloaded 10402 times)
Re: An error has occurred. See the log file [message #1722991 is a reply to message #1722964] Wed, 10 February 2016 11:34 Go to previous messageGo to next message
On 02/10/2016 08:42 AM, Ghazi Ennacer wrote:
> Hello everyone,
Bienvenu, Ghazi,
Did you check out this sticky post at forum's top?
https://www.eclipse.org/forums/index.php/t/198527/
Salut !
Re: An error has occurred. See the log file [message #1723030 is a reply to message #1722991] Thu, 11 February 2016 02:28 Go to previous messageGo to next message
Hello !!
Thanks for the help ! It works Now !
Thanks a lot !
Re: An error has occurred. See the log file [message #1773628 is a reply to message #1723030] Sun, 01 October 2017 11:51 Go to previous messageGo to next message
I am also having same issue on opening eclipse getting error -
"An Error has occurred
see the log file
/users/username/eclipse-workspace/.metadata/.log"
please help!
Re: An error has occurred. See the log file [message #1773634 is a reply to message #1773628] Mon, 02 October 2017 01:01 Go to previous messageGo to next message
What's in the .log? Which JVM are you using?
Re: An error has occurred. See the log file [message #1773731 is a reply to message #1773634] Tue, 03 October 2017 14:48 Go to previous messageGo to next message
I am not able to see the .metadata/.log file inside eclipse-workspace folder
Java version - 9
Eclipse - oxygen
Re: An error has occurred. See the log file [message #1773746 is a reply to message #1773731] Tue, 03 October 2017 23:00 Go to previous messageGo to next message
See https://wiki.eclipse.org/Configure_Eclipse_for_Java_9 for how to work around the Java 9 issue until Oxygen.1a is released in a few days.
Re: An error has occurred. See the log file [message #1774816 is a reply to message #1773746] Thu, 19 October 2017 18:32 Go to previous messageGo to next message
Hello, I had the same problem as the person just above. I've been struggling all day to install eclipse, it's just one problem after another. When you think it's over, well it's not. But praise the lord! I think it's over now
So! I clicked on the link, did what was indicated, and for those who are getting sleepy like me, don't want to read what is on this link, and just need a quick "how to", here is what you gotta do:
Open the eclipse.ini file with textedit (nothing else would work on my mac)
Add the " --add-modules=ALL-SYSTEM " line right after the " -Dosgi.requiredJavaVersion=1.8 " line. Only the first one will do.
Don't forget to change the eclipse.ini permission first so that you can edit it (cmd+i).
Close the file, open Eclipse again and it should work fine now just as it did for me.
I hope this is my last problem with Eclipse, because at this rate I'm not going to learn Java anytime soon.
Also, there is that now (it's on the picture), I hope it won't cause me any trouble
index.php/fa/31067/0/
Re: An error has occurred. See the log file [message #1774820 is a reply to message #1774816] Fri, 20 October 2017 01:09 Go to previous messageGo to next message
It probably will. You need to go to your Installed JREs preference page and make sure a 1.8 JDK is listed there. If one is still installed, you might be able to just click the Search button and find it automatically.
Re: An error has occurred. See the log file [message #1774828 is a reply to message #1774820] Fri, 20 October 2017 04:02 Go to previous message
Ok thanks, moved away the .9 file, downloaded the .8 jdk and it seems to be working now. Thank you :)
Previous Topic:mac OS Sierra An error has occurred
Next Topic:Empty toolbar descriptions
Current Time: Wed Jul 30 07:09:46 EDT 2025
Powered by FUDForum. Page generated in 0.07790 seconds
