Home » Eclipse Projects » Oomph » [SOLVED] Application of properties from a project setup file to a running IDE instance
[SOLVED] Application of properties from a project setup file to a running IDE instance [message #1722489] Fri, 05 February 2016 04:35 Go to next message
In my inital project setup file I enabled the line number ruler:
<setup:PreferenceTask
    xmi:version="2.0"
    xmlns:xmi="had_to_remove_this_link_before_posting"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    key="/instance/org.eclipse.ui.editors/lineNumberRuler"
    value="true">
  <description>Show line numbers on the left side of editors.</description>
</setup:PreferenceTask>
I installed my development environment using this project setup. The project setup file is consumed from a central location. So any changes in the project setup file can be seen by my development environment.
Later on the line number ruler setting was changed from "true" to "false" in the project setup file.
Now I would expect that this change is also reflected in my installed development environment instance. But that's not the case, even if I run the setup task trigger manually.
Am I missing something or is this use case not supported by Oomph?
Chris
[Updated on: Fri, 05 February 2016 06:15] by Moderator
Re: Application of properties from a project setup file to a running IDE instance [message #1722497 is a reply to message #1722489] Fri, 05 February 2016 04:44 Go to previous messageGo to next message
Hi Christoph,
In theory it's possible that the IDE doesn't listen to this preference. Have you checked in the Preferences dialog
whether it was changed?
Cheers
/Eike
http://www.esc-net.de
Am 05.02.2016 um 10:35 schrieb Christoph Zauner:
> xmi:version="2.0"
> value="true">
> Chris
Re: Application of properties from a project setup file to a running IDE instance [message #1722502 is a reply to message #1722497] Fri, 05 February 2016 05:11 Go to previous messageGo to next message
Hi Eike,
I have outlined the current behaviour below:
- Project setup file: false
- User setup file: true
- Eclipse preferences dialog: true
===> Setup task not triggered / setting in the preference dialog is not changed
- User setup file: - (I deleted this entry using the Oomph editor)
===> Setup task triggered / setting in the preference dialog is changed
It seems that as long as the preference in the user setup exists the state recorded in the project setup file is not applied...
Chris
Re: Application of properties from a project setup file to a running IDE instance [message #1722505 is a reply to message #1722502] Fri, 05 February 2016 05:31 Go to previous messageGo to next message
Christoph,
Yes, the different scopes have different precedence, i.e., Product
Catalog, Product, Product Version, Project Catalog, Project, Stream,
User, Installation, Workspace. And many tasks are designed to either
override or merge when they apparent in multiple scopes. Obviously you
can only have one possible setting for the line-numbers preference, so
the tasks from the different scopes will override each other, in
precedence order.
As such, the user can always override tasks either for all installations
and all workspaces in their user.setup, for a specific installation in
that installation's installation.setup, or for a specific workspace in
that workspace's workspace.setup.
On 05.02.2016 11:11, Christoph Zauner wrote:
> Hi Eike,
> not changed
> Chris
Re: Application of properties from a project setup file to a running IDE instance [message #1722511 is a reply to message #1722505] Fri, 05 February 2016 06:14 Go to previous messageGo to next message
Thanks a lot Eike (and Ed Wink) for the hints! The problem was that a lot of preference tasks in my project setup file were already present in my user setup file. I must have put them accidentally there.
Are there tools which support you when you want to determine if there are any tasks defined in multiple setup files? E.g. to see at one glace that the PreferenceTask for the "/instance/org.eclipse.ui.editors/lineNumberRuler" is defined in the user and the project setup files.
[Updated on: Fri, 05 February 2016 06:45] by Moderator
Re: Application of properties from a project setup file to a running IDE instance [message #1722514 is a reply to message #1722511] Fri, 05 February 2016 06:32 Go to previous message
Am 05.02.2016 um 12:14 schrieb Christoph Zauner:
> Thanks a lot Eike for the hint!
I think that was Ed :P
No, we don't have such tooling.
Cheers
/Eike
Previous Topic:command line
Next Topic:Preferences are recorded, but not loaded (!)
Current Time: Sat Jul 26 13:19:21 EDT 2025
Powered by FUDForum. Page generated in 0.08008 seconds
