Home » Modeling » TMF (Xtext) » configure multiple generators with XText 2.9
configure multiple generators with XText 2.9 [message #1722300] Wed, 03 February 2016 18:00 Go to next message
XText is really nice and exactly what I need. but after reading the docs and looking for info on the web, I still don't understand how I should configure my project, the mwe2, to produce multiple files from the same grammar.
I have modified the sample that uses the JvmModelInferrer to my needs, but now I need to add other generators to the workflow.
How is it done ?
Herve
Re: configure multiple generators with XText 2.9 [message #1722438 is a reply to message #1722300] Thu, 04 February 2016 14:32 Go to previous messageGo to next message
can you be a bit more specific about what you want to do? you can add as many fragments to the language generator as you want.
language = StandardLanguage {
			name = "org.xtext.example.mydsl.MyDsl"
			fileExtensions = "mydsl"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
			fragment = x.y.z.YourFragment {
YourFragment implements IXtextGeneratorFragment (probably subclass of AbstractXtextGeneratorFragment)
Re: configure multiple generators with XText 2.9 [message #1722441 is a reply to message #1722438] Thu, 04 February 2016 15:18 Go to previous messageGo to next message
(for the old xtext 2.8.x style of workflow the superclass and interfaces are IGeneratorFragment / DefaultGeneratorFragment
(I am not sure if I got your question at all)
[Updated on: Thu, 04 February 2016 16:07] by Moderator
Re: configure multiple generators with XText 2.9 [message #1722455 is a reply to message #1722300] Thu, 04 February 2016 18:02 Go to previous messageGo to next message
Thanks for your answer,
I followed the steps about the JVM language tutorial.
I get the xtext, the mwe2 and a MyDomainJvmModelInferrer that extends AbstractModelInferrer and a MyDomainGenerator that extends an AbstractGenerator.
I put the code that generates the java class in the MyDomainJvmModelInferrer, and it works.
But I don't see a reference of this class any where in the code, I don't understand how it is used by the workflow. Neither do I see a reference to the MyDomainGenerator.
Given a .mydomain source file I want to generate a java class and other related files, like a schema, etc...
Maybe a fragment is what I need, but I can't get how to use it, for ex, just to produce a .txt version of my source next to the .java.
A pointer to a simple example, or a simple source code would be appreciated
Herve
Re: configure multiple generators with XText 2.9 [message #1722461 is a reply to message #1722455] Thu, 04 February 2016 23:13 Go to previous messageGo to next message
this is a different question. you dont want to generate different stuff from your grammar, you want to generate different stuff from your models
- simply inferr more than one class in your inferrer
- subclass jvmmodelgenenerator (add a binding in the RuntimeModule/see below) and hook into doGenerate / internalDoGenerate and call fsa.doSomething as often as you want
- bind i delegating generator in the runtimemodule that delegates to your generator AND JvmModelGenerator
public class DelegatingGenerator implements IGenerator {
	@Inject
	JvmModelGenerator jvmModelGenerator;
	@Inject
	YourGenerator yourGenerator;
	public void doGenerate(Resource input, IFileSystemAccess fsa) {
		jvmModelGenerator.doGenerate(input, fsa);
		yourGenerator.doGenerate(input, fsa);
public class DomainmodelRuntimeModule extends AbstractDomainmodelRuntimeModule {
	public Class<? extends IGenerator> bindIGenerator() {
		return DelegatingGenerator,class
Re: configure multiple generators with XText 2.9 [message #1722475 is a reply to message #1722461] Fri, 05 February 2016 03:21 Go to previous messageGo to next message
Yes, exactly what I needed. It works perfectly.
Thank you for your time.
Re: configure multiple generators with XText 2.9 [message #1782110 is a reply to message #1722300] Sun, 18 February 2018 06:11 Go to previous messageGo to next message
Hello, So i followed your conversation and got a similiar problem.
So I got an old IGenerator and now i want to add the possibility to do something with an new IGenerator as well.
In my case I want to do something with the generated class of my jvmModelInferrer.
If i got your example right, I added a new RootGenerator and injected my old Generator and the jvmModelGenerator.
But how can i add a mapping or something, which gives me the possibility to get the reference to the gernated class of my jvmModelinferrer and use it in my old gernator?
This is my Workflow component:
	component = org.eclipse.xtext.generator.GeneratorComponent {
		register = QvtModelJoinGeneratorStandaloneSetup {}
		slot = "model"
		outlet = {
			path = targetDir
And in the QvtModelJoinModule i bind my RootGenerator:
public class QvtModelJoinModule extends AbstractModule {
	protected void configure() {
		bind(IGenerator2.class).to(IGeneratorRoot.class);
And finally the code of my IGeneratorRoot:
public class IGeneratorRoot implements IGenerator2 {
	@Inject
	@Inject
	QvtModelJoinGenerator qvtModelJoinGenerator;
	public void doGenerate(Resource input, IFileSystemAccess2 fsa, IGeneratorContext context) {
		qvtModelJoinGenerator.doGenerate(input, fsa, context);
If i save my textfile the jvmModelInferrer gets called and will generate a class.
So that part works.
So my question is, how can i give my qvtModelJoinGenerator the possibility to use the code that my jvmModelInferrer generated, or at least how to save the reference to that generated class?
Thx in advance
Re: configure multiple generators with XText 2.9 [message #1782133 is a reply to message #1722475] Mon, 19 February 2018 06:07 Go to previous messageGo to next message
Hey guys,
So i read your disscussion and i think i have a similiar problem.
I have a xtext grammar which i extended which xbase. I implemented the jvmModelInferrer which generates a class, when i start the eclipse application.
But now i want to connect my old IGenerator which the jvmModelGenerator. How can i use the class which gets generated by the jvmModelInferrer?
So i added an IRootGenerator where i inject my old generator and the jvmModelGenerator.
My question is now, how can i use the code, that the jvmModelInferrer generated, or at least how to save a reference to the class which got generated?
So my mwe2 workflow component looks like that:
		slot = "model"
		outlet = {
			path = targetDir
The QvtModelJoinGeneratorStandaloneSetup looks like that:
public class QvtModelJoinGeneratorStandaloneSetup extends ModelJoinStandaloneSetup {
	public Injector createInjector() {
		Injector injector = Guice.createInjector(new QvtModelJoinModule()).createChildInjector(new ModelJoinRuntimeModule());
	register(injector);
		return injector;
And the QvtModelJoinModule looks like that:
And at least the IGeneratorRoot:
	@Inject
	@Inject
Is that right?
Now how use the class, generated by jvmModelInferrer, in the qvtModelJoinGenerator?
Any ideas?
Re: configure multiple generators with XText 2.9 [message #1782237 is a reply to message #1782133] Tue, 20 February 2018 14:27 Go to previous messageGo to next message
you would have to use a custom wrapping file system access to record what the jvm model generator does.
e.g. val wrapper = new MyWrapper(originalfsa)
jvmmodelgenerator.doGenerate(....,wrapper, ..)
or you use subclassing of jvmmodelgenerator instead of delegating.
but i am not sure since i dont know your actual problem.
but i am not sure about the actually problem
Re: configure multiple generators with XText 2.9 [message #1782653 is a reply to message #1782237] Tue, 27 February 2018 07:07 Go to previous messageGo to next message
Thx for your answer, so i will try to specify my problem:
First of all i have grammar, which validation i want to improve.
So i implemented the jvmModelInferrer. This will create methods and parameters based on the file i want to check. The class, which gets generated has something like isValid(parameter1, parameter2){ ...body} method.
Now i want to implement something like validator class, which will have a reference to the created class and calls that method.
I have a generator class which has a doGenerateMethod and looks like that
	public void doGenerate(Resource input, IFileSystemAccess2 fileAccess, IGeneratorContext context) {
		super.doGenerate(input, fileAccess, context);
		Resource targetMetaModel = ((MetamodelGenerator) mmGenerator).getTargetMM();
		transformationAnnotationBasedGenerator.doGenerate(targetMetaModel, fileAccess);
		constraintsAnnotationBasedGenerator.doGenerate(targetMetaModel, fileAccess);
		editableTransformationGenerator.doGenerate(targetMetaModel, fileAccess);
So i would change it into:
		jvmmodelgenerator.doGenerate(wrapper)
#### How can the later generators now get the class that the jvmModelGenerator creates?
##### How would a wrapper class looks like?
Hope my question got more clear.
Maybe u got an example code where you reused the generated code of the jvmModelInferrer?
Thx
Re: configure multiple generators with XText 2.9 [message #1782655 is a reply to message #1782653] Tue, 27 February 2018 07:19 Go to previous message
this makes no sense to me at all. calling a method is no reuse.
jvmmodelinferring has nothing todo with the generators you later call on the inferred model.
so i dont understand why you need any information about what jvmmodelgenerator did
Previous Topic:Custom Lexer and Semantic Predicates issue
Next Topic:Xbase: Organize imports removes imported model packages
Current Time: Sat Jul 26 21:17:12 EDT 2025
Powered by FUDForum. Page generated in 0.09244 seconds
