Home » Eclipse Projects » NatTable » Nattable Export Excel Report contains filter string also( Nattable Export Excel Report contains filter string also)
Nattable Export Excel Report contains filter string also [message #1722142] Tue, 02 February 2016 23:54 Go to next message
Hello Dirk/Team,
Trying to use the nattable excel export functionality, working perfect.
Got two queries, please asssit
1. I Use a FilterRowHeaderComposite (Excel Text Box type filter) in my table. So, if I filter a column with some string (say, xyz) and do an export, then the report contains filter string as well (xyz).
Is there a way to hide the filterrow (Or need to override and customize)?
2. I beleive XSSF support is not there, this has to be performed by ourselves. But is there a way, we can hide the error pops up when a generated excel report is opened?
Error : The file format and extension don't match. The file could be corrupted or unsafe. Unless you trust its source, don't open it. Do you want to open it anyway?
<<I got some of your answers related to the 2 question, so you can ignore the 2nd question>>
[Updated on: Tue, 02 February 2016 23:56] by Moderator
Re: Nattable Export Excel Report contains filter string also [message #1722183 is a reply to message #1722142] Wed, 03 February 2016 04:34 Go to previous messageGo to next message
The simplest way to achieve this would be to hide the filterrow prior exporting and showing it after the export again. This way the filterrow would not be exported.
To do this you need to create and register a custom ExportAction that triggers the ToggleFilterRowCommand before and after the ExportCommand.
If anybody comes across this post for the second mentioned issue, the solution is to use the Apache POI extension of NatTable.
Re: Nattable Export Excel Report contains filter string also [message #1763889 is a reply to message #1722183] Mon, 22 May 2017 11:11 Go to previous messageGo to next message
Somehow iam not able to get this to work. The Exporter seems to wait for my Action to finish, before it starts the actual export. Thus the FilterRow is visible again.
To reproduce it, i used the _6031_GlazedListsFilterExample, added the export Button from _771_ExcelExportExample and added changed the SelectionAdapter to following:
natTable.doCommand(new ToggleFilterRowCommand());
natTable.doCommand(new ExportCommand(natTable.getConfigRegistry(), natTable.getShell()));
I also tried the register the CustomExportAction as suggested. That didn't work neither. Manually hiding the FilterRow (F3) and then Export works fine.
Do you have any suggestions how to wait for Exporter to finish before showing the FilterRow again?
Re: Nattable Export Excel Report contains filter string also [message #1764132 is a reply to message #1763889] Thu, 25 May 2017 11:32 Go to previous messageGo to next message
IIRC you need to execute the ExportCommand without a shell. This way it is executed in the main thread and not in a background thread.
Re: Nattable Export Excel Report contains filter string also [message #1764376 is a reply to message #1764132] Mon, 29 May 2017 05:45 Go to previous messageGo to next message
Thanks for the hint. I found the Javadoc of the NatExporter explaining it:
     * @param shell
     *            The {@link Shell} that should be used to open sub-dialogs and
     *            perform export operations in a background thread. Can be
     *            <code>null</code> but could lead to
     *            {@link NullPointerException}s if {@link IExporter} are
     *            configured, that use a {@link FileOutputStreamProvider}.
Sadly all ExcelExporter use the FileOuputStreamProvider. The Shell is used to open additional Dialogs (e.g. SaveDialog) and to determine if the export operations should be perfomed in a background thread or not. Maybe the latter could be made configurable, independent of the shell?
Shall I open a bug/feature request to make the (a)sync execution configurable?
Re: Nattable Export Excel Report contains filter string also [message #1764388 is a reply to message #1764376] Mon, 29 May 2017 06:20 Go to previous messageGo to next message
Feel free to do so
Re: Nattable Export Excel Report contains filter string also [message #1765301 is a reply to message #1764388] Thu, 08 June 2017 05:10 Go to previous message
Bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=517984
Previous Topic:Text Filter column doesn't work
Next Topic:"Interrupted Selection" creates Multiselection effect
Current Time: Sat Jul 26 02:47:59 EDT 2025
Powered by FUDForum. Page generated in 0.09687 seconds
