Home » Modeling » EMF » [CDO] Does the CDO Server product allow for gzip compression?
[CDO] Does the CDO Server product allow for gzip compression? [message #1722092] Tue, 02 February 2016 12:16 Go to next message
Hello all,
I've started developing a CDO compatibility plugin for the Epsilon languages [1, 2] and it is working nicely, but I would like to try enabling GZIP compression and see if it helps as well. I see that there is a GZIPStreamWrapper and a GZIPStreamWrapperInjector classes that I could use, and this thread mentions the setStreamWrapper/addStreamWrapper methods:
https://www.eclipse.org/forums/index.php/m/991500/?srch=compression+cdo#msg_991500
However, I assume I'd need to use them both in the server and the client. So far, I'm using the standard CDO Server product (as configured by Oomph), and I don't see any way to configure it to enable gzip compression. Would I need to roll my own product/application and add the GZIPStreamWrapperInjector myself?
[1]: http://eclipse.org/epsilon
[2]: https://github.com/epsilonlabs/emc-cdo
Kind regards,
Antonio
[Updated on: Tue, 02 February 2016 12:17] by Moderator
Re: [CDO] Does the CDO Server product allow for gzip compression? [message #1722096 is a reply to message #1722092] Tue, 02 February 2016 12:59 Go to previous messageGo to next message
Hi Antonio,
Currently there's no way to configure the transport with stream wrappers via the cdo-server.xml.
It would be great to have that. Maybe you want to work on a Gerrit contribution for that? A good start point is the
org.eclipse.net4j.TransportConfigurator.configureAcceptor(Element) method.
Cheers
/Eike
http://www.esc-net.de
Am 02.02.2016 um 18:16 schrieb Antonio Garcia-Dominguez:
> Hello all,
> I've started developing a CDO compatibility plugin for the Epsilon languages [1] and it is working nicely, but I would
> methods:
> [1]: https://github.com/epsilonlabs/emc-cdo
> Kind regards,
> Antonio
Re: [CDO] Does the CDO Server product allow for gzip compression? [message #1722248 is a reply to message #1722096] Wed, 03 February 2016 10:31 Go to previous messageGo to next message
I'll have a try once I get some time to work on it Smile. Thanks for the info!
Re: [CDO] Does the CDO Server product allow for gzip compression? [message #1722353 is a reply to message #1722248] Thu, 04 February 2016 04:21 Go to previous messageGo to next message
Le 03/02/2016 16:31, Antonio Garcia-Dominguez a écrit :
> I'll have a try once I get some time to work on it :). Thanks for the info!
Note that there is already a proposed patch by Esteban here:
https://git.eclipse.org/r/#/c/60937/
Pierre-Charles David - Obeo
Re: [CDO] Does the CDO Server product allow for gzip compression? [message #1722361 is a reply to message #1722353] Thu, 04 February 2016 04:58 Go to previous messageGo to next message
Am 04.02.2016 um 10:21 schrieb Pierre-Charles David:
> Note that there is already a proposed patch by Esteban here: https://git.eclipse.org/r/#/c/60937/
Good point!
But I thought that review/bugzilla was about configuring the server-side stream wrapping on a case by case basis
according to what the client actually used. My previous proposal was more about configuring it for all connections
through a particular acceptor, explicitely with new XML markup. That seems a little simpler to implement as it wouldn't
affect the client or the protocol between client and server.
Cheers
/Eike
Re: [CDO] Does the CDO Server product allow for gzip compression? [message #1722368 is a reply to message #1722361] Thu, 04 February 2016 05:28 Go to previous messageGo to next message
> Good point!
> stream wrapping on a case by case basis according to what the client
> all connections through a particular acceptor, explicitely with new XML
> markup.
From the commit message, it seems the patch adds support for this kind
of things in the XML config:
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<streamWrapper type="gzip"
protocol="cdo"
description="bufferSize:256"/>
</acceptor>
Which looks like "configuring it for all connections through a
particular acceptor, explicitely with new XML markup". Or maybe I'm
missing something (which is very possible)?
Re: [CDO] Does the CDO Server product allow for gzip compression? [message #1722369 is a reply to message #1722368] Thu, 04 February 2016 05:35 Go to previous messageGo to next message
Am 04.02.2016 um 11:28 schrieb Pierre-Charles David:
> From the commit message, it seems the patch adds support for this kind of things in the XML config:
> protocol="cdo"
> </acceptor>
> Which looks like "configuring it for all connections through a particular acceptor, explicitely with new XML markup".
Indeed, that looks very similar.
> Or maybe I'm missing something (which is very possible)?
No, I must have confused it ;-)
I'll ask Esteban sometime soon, jut to be sure. Thanks again for pointing it out.
Cheers
/Eike
Re: [CDO] Does the CDO Server product allow for gzip compression? [message #1722533 is a reply to message #1722353] Fri, 05 February 2016 08:39 Go to previous message
We've finished that patch now and it's available in the next build. Feedback is welcome ;-)
Cheers
/Eike
Previous Topic:XSD to Ecore
Next Topic:[CDO] DBException: Schema Locked with forceIndexes
Current Time: Mon Nov 03 10:49:21 EST 2025
Powered by FUDForum. Page generated in 0.04046 seconds
