Cobertura plugin not understanding my XML [message #1722066] |
Tue, 02 February 2016 09:59  |
I am trying to add code coverage step for a new language. I have created a cobertura XML file with lots of content and the Hudson plugin finds it and displays some info, but not much (showing only methods as covered (40%), all other statistics are listed as N/A or 0/0) . It displays file listings, but no lines are colored even though many lines are having hits in the XML file. I suspect that I am producing slightly incompatible XML file. It is surprisingly hard to find information about the exact syntax and semantics of the Cobertura XML file fields as expected by the Hudson plugin. Maybe you could direct me to the correct pages, or maybe you can see something obviously wrong in this excerpt from my XML:
<coverage line-rate="0.288095" branch-rate="0.254671" lines-covered="9005" lines-valid="31257" branches-covered="2181" branches-valid="8564" ccn="0.0" version="1.9" timestamp="1454335628">
<sources>
<source>D:/HBT/workspace/MyProductTrunkBuildWin/Production/BuildProducts/Windows/x64/Release/MyProductResources/MyProductCore/StdLib</source>
</sources>
<packages>
<package name="MyProductCore" line-rate="0.288095" branch-rate="0.254671" complexity="0.0">
<classes>
<class name="graph/graphs.proc" filename="graph/graphs.proc" line-rate="0.119565" branch-rate="0.0642202" complexity="0.0">
<methods>
<method name="graph::FindConnectedComponents" signature="()" line-rate="0.958333" branch-rate="1">
<lines>
<line number="582" hits="1" />
<line number="583" hits="1" />
<line number="586" hits="1" />
<line number="588" hits="1" />
<line number="591" hits="1" />
<line number="592" hits="1" />
<line number="593" hits="1" />
<line number="595" hits="21" branch = "true" condition-coverage="100% (2/2)"/>
<line number="597" hits="20" branch = "true" condition-coverage="100% (2/2)"/>
<line number="598" hits="18" />
<line number="599" hits="0" />
<line number="601" hits="2" />
<line number="602" hits="2" />
<line number="604" hits="11" branch = "true" condition-coverage="100% (2/2)"/>
<line number="606" hits="9" />
<line number="607" hits="9" />
<line number="609" hits="9" />
<line number="610" hits="9" />
<line number="611" hits="2" />
<line number="612" hits="9" />
<line number="614" hits="1" />
<line number="615" hits="1" />
<line number="617" hits="1" />
<line number="618" hits="1" />
</lines>
</method>
<method name="graph::Degrees" signature="()" line-rate="0" branch-rate="0">
<lines>
<line number="350" hits="0" />
<line number="351" hits="0" />
<line number="352" hits="0" />
</lines>
</method>
<!-- snipped 37,000 lines -->
</methods>
</class>
</classes>
</package>
</packages>
</coverage>
FUDForum. Page generated in 0.24276 seconds
