Home » Modeling » TMF (Xtext) » Xcore with xtext-maven-plugin: unmapped paths
Xcore with xtext-maven-plugin: unmapped paths [message #1420630] Wed, 10 September 2014 04:46 Go to next message
I am currently trying to use the xtext-maven-plugin in a Maven/Tycho build to generate code from an Xcore model.
I am following the approach outlined in this comment on Bug 410736, which uses the xtext-maven-plugin in conjunction with an Xcore model.
Unfortunately, for me build produces generates no code (just the stubs below target/xtext-temp):
[INFO] --- xtext-maven-plugin:2.7.0:generate (default) @ org.example.plugin ---
[INFO] Encoding: UTF-8
[INFO] Compiler source level: 1.6
[INFO] Compiler target level: 1.6
[INFO] Using common types.
[INFO] Collecting source models.
[INFO] Installing type provider.
[INFO] Generating stubs into /tmp/plugins/org.example.plugin/target/xtext-temp/stubs
[INFO] Compiling stubs located in /tmp/plugins/org.example.plugin/target/xtext-temp/stubs
[INFO] Installing type provider for stubs.
[INFO] Starting generator for input: 'model.xcore'
java.io.IOException: The path '/org.example.plugin/plugin.properties' is unmapped
As far as I can see, the situation with Xcore differs from things like the well-documented Hero Language example in that the Xcore code generator needs to access external files to execute directives like the following
@GenModel(modelDirectory="/org.example.plugin/src-gen/")
So, how does one specify such a mapping? I browsed through most of the classes in the resulting stacktrace
java.io.IOException: The path '/org.example.plugin/plugin.xml' is unmapped
	at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl.createOutputStream(PlatformResourceURIHandlerImpl.java:501)
	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createOutputStream(ExtensibleURIConverterImpl.java:349)
	at org.eclipse.xtext.common.types.access.impl.ClasspathTypeProvider$JavaURIConverter.createOutputStream(ClasspathTypeProvider.java:89)
	at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.createOutputStream(AbstractGeneratorAdapter.java:2388)
	at org.eclipse.emf.ecore.xcore.generator.XcoreGenModelGeneratorAdapterFactory$2.createOutputStream(XcoreGenModelGeneratorAdapterFactory.java:166)
	at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generateText(AbstractGeneratorAdapter.java:737)
	at org.eclipse.emf.codegen.ecore.genmodel.generator.GenModelGeneratorAdapter.generateModelManifest(GenModelGeneratorAdapter.java:211)
	at org.eclipse.emf.codegen.ecore.genmodel.generator.GenModelGeneratorAdapter.generateModel(GenModelGeneratorAdapter.java:155)
	at org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGeneratorAdapter.doGenerate(GenBaseGeneratorAdapter.java:215)
	at org.eclipse.emf.codegen.ecore.generator.AbstractGeneratorAdapter.generate(AbstractGeneratorAdapter.java:317)
	at org.eclipse.emf.codegen.ecore.generator.Generator.generate(Generator.java:708)
	at org.eclipse.emf.codegen.ecore.generator.Generator.generate(Generator.java:619)
	at org.eclipse.emf.ecore.xcore.generator.XcoreGenerator.generateGenModel(XcoreGenerator.java:279)
	at org.eclipse.emf.ecore.xcore.generator.XcoreGenerator.doGenerate(XcoreGenerator.java:227)
	at org.eclipse.xtext.builder.standalone.StandaloneBuilder.generate(StandaloneBuilder.java:398)
	at org.eclipse.xtext.builder.standalone.StandaloneBuilder.launch(StandaloneBuilder.java:279)
	at org.eclipse.xtext.maven.XtextGenerator.internalExecute(XtextGenerator.java:156)
	at org.eclipse.xtext.maven.XtextGenerator.execute(XtextGenerator.java:129)
but had a very hard time figuring out where the mapping is supposed to come from (lots of DI magic happening there).
Any advice?
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1420646 is a reply to message #1420630] Wed, 10 September 2014 05:08 Go to previous messageGo to next message
@GenModel(modelDirectory="./src-gen" ) doesn't work for you?
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1420662 is a reply to message #1420646] Wed, 10 September 2014 05:32 Go to previous messageGo to next message
Hi Dennis. Thanks for your help.
@GenModel(modelDirectory="./target/generated-sources/xcore")
indeed improved the situation a bit: No more IOExceptions. Smile
Alas, not everything is perfect. The files are all generated in the "src-gen" folder, even though I specify a different one. Is this a known issue?
Also, I don't see a way (with the plugin-less "./" approach) to use an editDirectory that's in a different plugin.
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1420798 is a reply to message #1420662] Wed, 10 September 2014 09:48 Go to previous messageGo to next message
To make things a bit more concrete, I've uploaded a change to Gerrit that illustrates our use of @GenModel(modelDirectory). Can someone tell me what we do wrong there?
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1421027 is a reply to message #1420630] Wed, 10 September 2014 17:09 Go to previous messageGo to next message
That aspect of things works for me when everything is in a single annotation, i.e.:
@GenModel(modelDirectory="/dsl/target/generated-sources/emf", forceOverwrite="true", updateClasspath="false", complianceLevel="5.0")
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1421354 is a reply to message #1421027] Thu, 11 September 2014 04:52 Go to previous messageGo to next message
Hi Richard. Thanks for the reply.
Unfortunately, even putting everything into a single @GenModel annotation doesn't help.
If I omit "modelDirectory", no code is generated. If a add "modelDirectory", code is indeed generated but always into src-gen. So, obviously, the parameter is read but apparently not use like I think it would be.
Richard, do you have a outputConfiguration specified in your pom.xml? I don't - and also have no idea how that would interact with the "modelDirectory" in @GenModel. Could you have a look at my pom.xml please?
Best wishes,
Andreas
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1421369 is a reply to message #1421354] Thu, 11 September 2014 05:16 Go to previous messageGo to next message
Hm, I can get this to work for now if I use an explicit outputConfiguration:
<languages>
	<language>
		<setup>org.eclipse.emf.codegen.ecore.xtext.GenModelSupport</setup>
	</language>
 	<language>
		<setup>org.eclipse.emf.ecore.xcore.XcoreStandaloneSetup</setup>
		<outputConfigurations>
			<outputConfiguration>
				<outputDirectory>target/generated-sources/xcore</outputDirectory>
			</outputConfiguration>
		</outputConfigurations>
	</language>
</languages>
But this kind of defeats the purpose of @GenModel(modelDirectory); why do I have to maintain the same information twice, once for the IDE and once for Maven? Also, I don't see this working anymore as soon as I start using, e.g., @GenModel(editDirectory) in addition to @GenModel(modelDirectory). How would it work then?
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1421480 is a reply to message #1421369] Thu, 11 September 2014 08:20 Go to previous messageGo to next message
> <languages>
> <language>
> </language>
> <language>
> </language>
> </languages> But this kind of defeats the purpose of
> would it work then?
I've just answered to another similar post: I'm using a different
approach which works for me:
You can run an mwe2 file from maven (using the fornax plug-in), as you
can see here:
https://github.com/LorenzoBettini/xsemantics/blob/master/plugins/it.xsemantics.dsl/src/it/xsemantics/dsl/GenerateXsemanticsModel.mwe2
Note that this also uses de.itemis.xcore2java.XcoreReader originally
written by Christian (you can find that in the sources of the above
project).
The only thing you need to remember is to put the 1.5 Java compliant
setting in the xcore (see the xcore file in the above project),
otherwise when running the workflow it will not generate type parameters
in the model classes. That specification would be useless in the IDE,
but at least you don't need to maintain duplicate information.
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1421492 is a reply to message #1421480] Thu, 11 September 2014 08:43 Go to previous messageGo to next message
Hi Lorenzo,
thanks for the suggestion. I was aware of the fornax-maven-plugin but not of the XcoreReader. That being said, having to specify a mwe2 workflow in addition to the build workflow already described in the POM doesn't seem easier to me. Why specify the DirectoryCleaner if you have the maven-clean-plugin already configured? What's the advantage of using the workflow? (Maybe I should read your book to find out Wink)
Anyway, to me as a long-time Maven user and short-time Xtext user, having a single plugin goal xtext-maven-plugin:generate bound to the generate-source phase while leaving everything else to the established Maven plugins seems very natural, so I'd really like to stick with that plugin for now.
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1421524 is a reply to message #1421492] Thu, 11 September 2014 09:30 Go to previous messageGo to next message
On 11/09/2014 14:43, Andreas Sewe wrote:
> Hi Lorenzo,
> the workflow? (Maybe I should read your book to find out ;))
> plugin for now.
Hi Andreas
(you won't find this detail in the book ;)
I'm not saying there are advantages: it's just that by using the
xtext-maven-plugin I had so many troubles that blocked me, while with
the mwe2 workflow I managed to make it work (not to mention that it's
easier to have a try from the IDE itself by running the workflow; the
DirectoryCleaner is useful when you run it from Eclipse).
cheers
Lorenzo
Xtext Book:
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1690459 is a reply to message #1421524] Fri, 27 March 2015 08:23 Go to previous messageGo to next message
Hi Andreas,
I'm currently facing a similar troubles trying to integrate xcore into a command-line Maven build. (More info: what we are doing with XText is UI independent - it won't even run inside of Eclipse.)
I'm curious: did you eventually succeed with the xtext-maven-plugin approach? If so, would you be able to post some relevant pom snippets for that? (I'm both a short-time Maven user and a short-time XText user.)
It sounds more appealing & natural if it could integrate with Maven better. Currently I'm banging my head with how to get XCore to generate code from a mwe2 workflow, launched from command-line Maven. (Inside Eclipse it all just generates magically after any edit+build.)
Kind regards,
Luke Usherwood
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1690466 is a reply to message #1690459] Fri, 27 March 2015 08:39 Go to previous messageGo to next message
Hi Luke,
maybe this test project will help you.
https://github.com/eclipse/xtext/tree/master/maven/org.eclipse.xtext.maven.plugin/src/test/resources/it/generate/xcore-lang
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1690467 is a reply to message #1690459] Fri, 27 March 2015 08:42 Go to previous messageGo to next message
Luke Usherwood wrote on Fri, 27 March 2015 08:23
Hi Andreas,
Here's what I ultimately came up with: https://git.eclipse.org/c/recommenders/org.eclipse.recommenders.git/tree/plugins/org.eclipse.recommenders.stacktraces.model?id=v2.1.13. Have a look at the pom.xml and the XCore model in the models directory.
Hope that helps.
Andreas
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1690474 is a reply to message #1690467] Fri, 27 March 2015 10:13 Go to previous messageGo to next message
Thanks!
I gather from "<packaging>eclipse-plugin</packaging>" that your project uses Tycho? Should the xtext-maven-plugin run ok without Tycho?
I've tried embedding that in my pom (and disabled my xcore generation attempt from the mwe2) and it appears to execute this plugin without printing any errors. But all I seem to get is a bunch of .class files generated into target/xtext-temp/ - but not the ones I'd expect from Xcore; in fact I don't see any .java files derived from Xcore anywhere either. Sad
Similarly to the above, setting @GenModel(modelDirectory= seems to correctly modify the in-Eclipse code-generation, but not the command-line Maven build. However the <outputConfigurations> trick mentioned above does not seem to help either - but probably because it's just not generating anything.
Any ideas?
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1690480 is a reply to message #1690474] Fri, 27 March 2015 10:31 Go to previous messageGo to next message
Hi Dennis, Thanks for that minimal example - that looks useful. I've already learned "maven-clean-plugin" Smile and it helped me spot a typo (copy-o?) in my pom (sourceRoot: models -> model). I get an error now, so I think that's progress Smile I.e. it's actually trying to generate something now.
Looks like I just need to work my way through the deps & versions after the weekend and some sleep.
Thanks to you both for the quick replies.
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1690483 is a reply to message #1690480] Fri, 27 March 2015 10:47 Go to previous messageGo to next message
Laughing Thats good if it at least try to do something useful ! Smile
Re: Xcore with xtext-maven-plugin: unmapped paths [message #1721793 is a reply to message #1690483] Sat, 30 January 2016 15:44 Go to previous message
I like to catch up this thread for a question concerning unmapped paths with xtext-maven-plugin. I have a really big project (M2M approach with a lot of generated xcore classes). When generating Java, Xcores creates an *.ecore file, too. It's placed inside the src-gen folder (when using the build in Eclipse).
Xtext-maven-plugin complains that the generated ecore file is unmapped
java.io.IOException: The path '/src-gen/org/buildingsmart/ifc4/impl/ifc4.ecore' is unmapped
lerImpl.java:501)
java:349)
        at org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfChangedWithMemoryBuffer(ResourceImpl.java:1234)
        at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:985)
        at org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageGeneratorAdapter.generatePackageSerialization(Gen
ackageGeneratorAdapter.java:544)
        at org.eclipse.emf.codegen.ecore.genmodel.generator.GenPackageGeneratorAdapter.generateModel(GenPackageGenerato
Adapter.java:213)
ava:215)
        at org.eclipse.emf.ecore.xcore.generator.XcoreGenerator.generateGenModel(XcoreGenerator.java:280)
        at org.eclipse.emf.ecore.xcore.generator.XcoreGenerator.doGenerate(XcoreGenerator.java:228)
        at org.eclipse.xtext.builder.standalone.StandaloneBuilder.generate(StandaloneBuilder.java:476)
        at org.eclipse.xtext.builder.standalone.StandaloneBuilder.launch(StandaloneBuilder.java:319)
        at org.eclipse.xtext.maven.XtextGenerator.internalExecute(XtextGenerator.java:164)
        at org.eclipse.xtext.maven.XtextGenerator.execute(XtextGenerator.java:140)
        at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:132)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
        at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
        at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
        at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
        at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder
java:51)
        at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:120)
        at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:355)
        at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:155)
        at org.apache.maven.cli.MavenCli.execute(MavenCli.java:584)
        at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:216)
        at org.apache.maven.cli.MavenCli.main(MavenCli.java:160)
        at java.lang.reflect.Method.invoke(Method.java:497)
        at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
        at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
        at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
        at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Changes to output directory or model path in Xcore do not have any effect. Within the source of xtext-maven-plugin I found a property "sourceMappings". So my idea is to map the "unmapped" path manually. Is it right? Anyone faces a similiar problem?
     <language>
				<outputDirectory>${project.basedir}/src-gen</outputDirectory>
				<sourceMappings>
					<sourceFolder>/src-gen/org/buildingsmart/ifc4/impl</sourceFolder>
					<outputDirectory>${project.basedir}/src-gen/org/buildingsmart/ifc4/impl</outputDirectory>
				</sourceMappings>
    </language>
When I start this maven build, it crashes with an error
[ERROR] Failed to execute goal org.eclipse.xtext:xtext-maven-plugin:2.8.4:generate (default) on project org.buildingsmart.ifc4: Unable to parse configuration of mojo org.eclipse.xtext:xtext-maven-plugin:2.8.4:generate for parameter sourceFolder: Cannot find default setter in class org.eclipse.xtext.maven.OutputConfiguration$SourceMapping
Thanks a lot for help!
Previous Topic:using xtend or xpand for code generation
Next Topic:xtext, how to export plug-ins
Current Time: Mon Jul 21 13:50:33 EDT 2025
Powered by FUDForum. Page generated in 0.08746 seconds
