Home » Eclipse Projects » Oomph » What is the PathVariableTask supposed to do?
What is the PathVariableTask supposed to do? [message #1721774] Fri, 29 January 2016 23:51 Go to next message
Looking at the PathVariable task, it looks like it's supposed to help you resolve path URI's to a variable, which if is the case, would be very useful.
Unfortunately, I was unable to find any documentation on it.
I tried using platform:/ uri's.. as below..
<setupTask
        xsi:type="projects:PathVariableTask"
        id="apmdev"
        name="maven_settings"
        uri="platform:/meta/org.eclipse.m2e.core/maven_settings.xml">
      <description></description>
</setupTask>
but the variable was undefined, and I just got a prompt to define it in the setup wizard.
I ended up just using a ${osgi.instance.area|file}.metadata/.plugins/org.eclipse.m2e.core/maven_settings.xml" variable instead. Which seems like a bit of a hack compared to the platform:uri approach (which worked great in my ResourceCreationTasks
Anyway, if I ever write another oomph setup, it would be good to know how PathVariable was intended to be used.
Re: What is the PathVariableTask supposed to do? [message #1721785 is a reply to message #1721774] Sat, 30 January 2016 06:35 Go to previous messageGo to next message
Duane,
Good question. I had to look at the code to see what that's implemented
that to do. It's intended to set path variables the same as you'd do in
Window -> Preferences -> General -> Workspace -> Linked Resources.
In the UI you see it only allows files and folders, but the underlying
API, org.eclipse.core.resources.IPathVariableManager.setValue(String,
IPath), is deprecated in favor of
org.eclipse.core.resources.IPathVariableManager.setURIValue(String, URI).
But it's not so clear (not documented) what forms of URIs are all
permitted here. It's probably best to assume that only "file:" URIs are
permitted.
So a path variable task is generally useful if your workspace uses
linked resources and those links are defined using path variables.
> very useful.
> <setupTask
> id="apmdev"
> </setupTask>
Re: What is the PathVariableTask supposed to do? [message #1721800 is a reply to message #1721785] Sun, 31 January 2016 00:10 Go to previous messageGo to next message
Cheers, bro, thanks for checking for me. Seems like it would be useful. Which scope would those variables become "active". ie; when would they become substitable. I'm assuming not in BOOSTRAP, and perhaps not in oomph setup at all. Only when the workspace was actually materialized, right?
Re: What is the PathVariableTask supposed to do? [message #1721807 is a reply to message #1721800] Sun, 31 January 2016 02:50 Go to previous message
Duane,
They must run in the IDE, so they will perform in startup and manual
trigger.
Previous Topic:NPE while using the installer
Next Topic:Default value for unsigned content?
Current Time: Fri Jul 25 09:08:29 EDT 2025
Powered by FUDForum. Page generated in 0.37662 seconds
