Home » Modeling » OCL » Parsing error in a UML::Constraint(Unable to parse a simple constraint in Papyrus)
Parsing error in a UML::Constraint [message #1720195] Fri, 15 January 2016 02:47 Go to next message
I created a sample model in Papyrus with single constraint following the instructions given by the OCL documentation for defining a Class invariant. I get a the following parsing error on the constraint:
Failed to load 'platform:/resource/Test/Sample.uml.oclas
What do I need to do to have this file generated?
Re: Parsing error in a UML::Constraint [message #1720335 is a reply to message #1720195] Sun, 17 January 2016 11:51 Go to previous messageGo to next message
Without a repro, you are unlikely to get a solution.
*.oclas is the, normally only internal, name of a model normalized to
the OCL Pivot Abstract Syntax. *.oclas is normally registered so that
any access strips the extension, tries again to load the unnormalized
file, then normalizes it. (*.oclas is the prototype for the long overdue
ability to have a defined OCL XMI.)
Possibly you have fallen foul of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=485668
although your error message bears little resemblance to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=483181
The above bug is fixed in the latest OCL builds towards Mars.2 and Neon.
http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/ocl/downloads/drops/6.0.2/N201601131454/mdt-ocl-Update-N201601131454.zip
http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/ocl/downloads/drops/6.1.0/N201601170942/mdt-ocl-Update-N201601170942.zip
Ed Willink
Re: Parsing error in a UML::Constraint [message #1721606 is a reply to message #1720335] Thu, 28 January 2016 10:27 Go to previous messageGo to next message
Ed,
Thanks for your reply. I apologize for taking so long to react, I was stuck on another topic.
I updated my OCL version with the one you provide (for Mars) but the error is still there.
I provide the model this time.
  • Attachment: Sample.zip
    (Size: 4.22KB, Downloaded 278 times)
Re: Parsing error in a UML::Constraint [message #1721761 is a reply to message #1721606] Fri, 29 January 2016 16:28 Go to previous messageGo to next message
Sorry, I am unable to load your model. It uses SysML 1.4 facilities that
are not part of the Papyrus 1.2.0M4 distribution and not in the Papyrus
Additional Compoents.
Ed Willink
On 28/01/2016 15:27, Yves BERNARD wrote:
> Ed,
Re: Parsing error in a UML::Constraint [message #1721795 is a reply to message #1721761] Sat, 30 January 2016 16:58 Go to previous messageGo to next message
Once I upgraded this model to the SysML 1.4 profile in my installation (ie. after the migrate profile functionality from Papyrus pops in), your constraint parses fine. Which version of papyrus/sysml1.4 are you running?
Re: Parsing error in a UML::Constraint [message #1721865 is a reply to message #1721795] Mon, 01 February 2016 02:34 Go to previous messageGo to next message
Hi Klaas,
Interesting...
Here is the info I can get from the SysML1.4 plugin:
Papyrus Sysml 1.4 Feature (Incubation) 0.7.0.201511250947 org.eclipse.papyrus.sysml14.feature.feature.group Eclipse Modeling Project
Re: Parsing error in a UML::Constraint [message #1721866 is a reply to message #1721865] Mon, 01 February 2016 02:48 Go to previous messageGo to next message
I modified the sample in order to remove the SysML profile and then the problem vanished...
If I reapply the SysML 1.4 profile the problem reappears but it is not with the case with the profile corresponding to SysML 1.1.
So it appears that there is an incompatibility between the version of the SysML 1.4 profile plugin I use and the current version of OCL.
Klaas, I'm interested to know which version of this plugin you use.
Re: Parsing error in a UML::Constraint [message #1721876 is a reply to message #1721866] Mon, 01 February 2016 04:15 Go to previous messageGo to next message
AFAIK if you're using SysML 1.4, bleeding edge is the most stable (generally Smile. I'm using
Papyrus Sysml 1.4 Feature (Incubation) 0.8.1.201601221455 org.eclipse.papyrus.sysml14.feature.feature.group Eclipse Modeling Project
from the hudson update: https://hudson.eclipse.org/papyrus/view/Sysml/job/papyrus-sysml-mars/ws/releng/org.eclipse.papyrus.sysml14.p2/target/repository/
(see also https://hudson.eclipse.org/papyrus/view/Sysml/ )
HTH,
Klaas
Re: Parsing error in a UML::Constraint [message #1721878 is a reply to message #1721876] Mon, 01 February 2016 04:22 Go to previous message
So, it looks like the version I use is outdated a bit.. Wink
I'm going to upgrade it.
Thanks!
Previous Topic:EMF validation with several OCL documents
Next Topic:Problems with hierarchical/embedded model packages
Current Time: Wed Jul 30 13:15:48 EDT 2025
Powered by FUDForum. Page generated in 0.05743 seconds
