Home » Eclipse Projects » Oomph » NPE while using the installer
NPE while using the installer [message #1721675] Fri, 29 January 2016 01:58 Go to next message
I see the following error while using the Oomph installer. It happens after I make some minor changes to the setup file - for example change the value of git.clone.remoteURI or remove version information from the Requirement under Target Platform.
Please note that the setup file contains no validation errors.
I cannot share the setup file and the error log is the only information I could give about the error condition.
at org.eclipse.oomph.setup.internal.core.StringFilterRegistry$4.filter(StringFilterRegistry.java:86)
at org.eclipse.oomph.setup.internal.core.StringFilterRegistry.filter(StringFilterRegistry.java:366)
at org.eclipse.oomph.setup.internal.core.AbstractSetupTaskContext.filter(AbstractSetupTaskContext.java:468)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.filter(SetupTaskPerformer.java:2021)
at org.eclipse.oomph.setup.util.StringExpander.expandString(StringExpander.java:126)
at org.eclipse.oomph.setup.util.StringExpander.expandString(StringExpander.java:69)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.expandVariableKeys(SetupTaskPerformer.java:2374)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.initTriggeredSetupTasks(SetupTaskPerformer.java:736)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.<init>(SetupTaskPerformer.java:246)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.create(SetupTaskPerformer.java:3566)
at org.eclipse.oomph.setup.ui.wizards.SetupWizardPage.createPerformer(SetupWizardPage.java:147)
at org.eclipse.oomph.setup.internal.installer.ExtensionPage.enterPage(ExtensionPage.java:79)
at org.eclipse.oomph.setup.ui.wizards.SetupWizard.pageChanged(SetupWizard.java:414)
at org.eclipse.jface.wizard.WizardDialog$9.run(WizardDialog.java:1505)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.wizard.WizardDialog.firePageChanged(WizardDialog.java:1502)
at org.eclipse.jface.wizard.WizardDialog.update(WizardDialog.java:1308)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1234)
at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1208)
at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1197)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1194)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDialog.java:885)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:425)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:619)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at org.eclipse.oomph.setup.internal.installer.InstallerDialog.show(InstallerDialog.java:373)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.run(InstallerApplication.java:200)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:300)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Re: NPE while using the installer [message #1721679 is a reply to message #1721675] Fri, 29 January 2016 02:24 Go to previous messageGo to next message
Comments below.
On 29.01.2016 07:58, Neeraj Bhusare wrote:
> at
This looks specifically like a problem here:
String result = URI.decode(uri.lastSegment());
if (result.endsWith(".git"))
result = result.substring(0, result.length() - 4);
with the URI not having a last segment.
That looks like a bug, but also suggests that your URI is probably
bogus. I can't comment on the other problem because I can't imagining
it producing this same stack trace.
In any case, you should open a bugzilla with a test case that reproduces
the problem if you get NPEs.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
Re: NPE while using the installer [message #1721729 is a reply to message #1721679] Fri, 29 January 2016 09:05 Go to previous message
Hi Ed,
The URI I used is of the form - https://username:password@github.com/path/to/repo.git
Please note that the installer worked intermittently.
Bug - https://bugs.eclipse.org/bugs/show_bug.cgi?id=486822
Thanks for responding.
Previous Topic:Annotate tasks with "Restart needed"
Next Topic:What is the PathVariableTask supposed to do?
Current Time: Sat Jul 19 04:48:03 EDT 2025
Powered by FUDForum. Page generated in 0.03530 seconds
