Home » Modeling » TMF (Xtext) » Cannot root twice
Cannot root twice [message #1721621] Thu, 28 January 2016 11:45 Go to next message
I inferr a jvm model from my Xbase based domainmodel like DSL.
Also I generate a hibernate mapping XML file which I do in the ModelGenerator.
There I need the resolved types of my features. So far so good.
But as soon as I add an annotation with JvmCustomAnnotationValue's to a JvmField I get that exception in my XML compiler:
java.lang.RuntimeException: Cannot root twice
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver$1.add(DefaultBatchTypeResolver.java:73)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver$1.add(DefaultBatchTypeResolver.java:1)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver$1.add(LogicalContainerAwareReentrantTypeResolver.java:318)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver$1.add(LogicalContainerAwareReentrantTypeResolver.java:1)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.recordAnnotationExpressions(LogicalContainerAwareReentrantTypeResolver.java:601)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.recordAnnotationExpressions(LogicalContainerAwareReentrantTypeResolver.java:587)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._recordExpressions(LogicalContainerAwareReentrantTypeResolver.java:425)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.recordExpressions(LogicalContainerAwareReentrantTypeResolver.java:416)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver._recordExpressions(LogicalContainerAwareReentrantTypeResolver.java:439)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.recordExpressions(LogicalContainerAwareReentrantTypeResolver.java:412)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.prepare(LogicalContainerAwareReentrantTypeResolver.java:401)
	at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareReentrantTypeResolver.computeTypes(LogicalContainerAwareReentrantTypeResolver.java:689)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:163)
	at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:139)
	at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getDelegate(CompoundReentrantTypeResolver.java:108)
	at org.eclipse.xtext.xbase.typesystem.internal.CompoundReentrantTypeResolver.getActualType(CompoundReentrantTypeResolver.java:202)
	at org.eclipse.xtext.xbase.typesystem.internal.ForwardingResolvedTypes.getActualType(ForwardingResolvedTypes.java:73)
I'm calling this via "return typeResolver.resolveTypes( x ).getActualType( x );"
This is really weird because the annotation is already added to the JvmField and there is absolutely no need to add them again. Also I'm just want to get the already resolved type. Why the heck is the annotation added again then to something which throws an exception.
Is this a bug? I assume just removing the exception throw and everything will work fine...
Re: Cannot root twice [message #1721624 is a reply to message #1721621] Thu, 28 January 2016 12:15 Go to previous message
Can you Share a small example reproducing the problem
Previous Topic:Reference to static field instances
Next Topic:Getting all values under a category
Current Time: Mon Jul 21 11:43:44 EDT 2025
Powered by FUDForum. Page generated in 0.03718 seconds
