Home » Archived » Eclipse Process Manager (Stardust) » XML Document Data - Choosing the element name(When selecting the Element Name system replies: Cannot parse XSD file.: local part cannot be "null" when creating a QName)
XML Document Data - Choosing the element name [message #1721491] Wed, 27 January 2016 14:23 Go to next message
Error in eclipse process modeller:
To reproduce:
1) Add data of type 'XML Document' to a Process Definition
2) Edit the properties:
a) Schema Type: XSD
b) Type Declaration URL: Enter the path to an XSD file.
For the XSD I chose a few different files but always got the same error. Sample attached.
3) Click the Browse button to see error
Screenshot of error attached.
index.php/fa/24804/0/
[Updated on: Thu, 28 January 2016 08:39] by Moderator
Re: XML Document Data - Choosing the element name [message #1721533 is a reply to message #1721491] Thu, 28 January 2016 01:20 Go to previous messageGo to next message
Can you attach the relevant process model as well?.
Re: XML Document Data - Choosing the element name [message #1721581 is a reply to message #1721533] Thu, 28 January 2016 08:40 Go to previous messageGo to next message
Process model attached.
Re: XML Document Data - Choosing the element name [message #1721670 is a reply to message #1721581] Fri, 29 January 2016 00:27 Go to previous message
Roger,
Ashish already commented something similar on the other thread. The primitive XML data type is superseded by the Structured Data type.
The XML data type is basically a string data with xpath support for data paths. The structure data type provides way more sophisticated support, browsable data structure, indexing configuration for particular fields, preferences for UI generation, ootb parsing and serialization, support in transformation application, ...
Please use structured data. The XML data will likely be removed in the near future.
Rob
Previous Topic:Starting a process model with an XML parameter fails with exception
Next Topic:Example of Process Model that iterate over structured data with maxOccurance > 1
Current Time: Sat Jul 19 04:47:34 EDT 2025
Powered by FUDForum. Page generated in 0.03746 seconds
