Home » Modeling » TMF (Xtext) » Splitting a model into several files? Scoping?
icon5.gif  Splitting a model into several files? Scoping? [message #654056] Sun, 13 February 2011 14:11 Go to next message
Hi all,
for a newbie scoping does not exactly seem to be the easiest part to understand. So maybe somebody can help...
My model contains applications, and applications contain entities with attributes. Attributes can refer to entities:
Attribute:
type=AttributeTypeReference name=ID ";";
AttributeTypeReference:
referenced=[AttributeType|QualifiedName];
AttributeType:
DataType | Entity;
QualifiedName:
ID ("." ID)*;
I want to split an application's definition into several files:
file 1:
app A {
entity A1 {
String x;
file 2:
app A { // same applications as above
entity A2 {
A.A1 x; // reference to the same application's reference
B.B1 y; // qualified reference to another application's entity
file 3:
app B {
entity B1 {
While the qualified reference "B.B1 y;" is perfectly fine, I would like to avoid having to qualify the reference "A.A1 x;" since this is referring to the same application. Insted I would like to write:
entity A2 {
After playing around with ScopeProviders for several hours I came up with the clever idea that somebody might already have solved this?
[Updated on: Sun, 13 February 2011 14:12] by Moderator
Re: Splitting a model into several files? Scoping? [message #1721413 is a reply to message #654056] Wed, 27 January 2016 04:55 Go to previous messageGo to next message
I have imported two different ecore model to xtext with Ecore2Xtext. In both of them cross-reference is done with literals like this:
'page' page=[gcore::Page|EString]
In runtime the output as follows
page "gcoreI.EditPerson"
But what I expected was
page gcoreI.EditPerson
therefor I changed the literal to
'page' page=[gcore::Page|QualifiedName]
and in addition to that I defined the QualifiedName production rules.
QualifiedName:
ID ("." ID)*;
But in another grammar I have changed only the following configuration
	//fragment = scoping.ImportURIScopingFragment auto-inject {}
	//fragment = exporting.SimpleNamesFragment auto-inject {}
to this configuration
			fragment = scoping.ImportNamespacesScopingFragment auto-inject {}
			fragment = exporting.QualifiedNamesFragment auto-inject {}
to have this output
menu DefaultMenu
for this literal
'menu' menu=[Menu|EString]
instead of an output as string
menu "DefaultMenu"
Although in both of them I wanted to have cross-reference and document-cross-reference like an id instead of String, but I should have used two different method?
-> one of them with workflow
-> the other with production rule
[Updated on: Wed, 27 January 2016 04:59] by Moderator
Re: Splitting a model into several files? Scoping? [message #1721415 is a reply to message #1721413] Wed, 27 January 2016 05:10 Go to previous messageGo to next message
Hi I don't understand this. Through qualifiednameprovider you define how objects are put to the xtext index. Through the grammar how they are serialized: Id string FQN ...
So what is your actual problem
Re: Splitting a model into several files? Scoping? [message #1721432 is a reply to message #1721415] Wed, 27 January 2016 08:14 Go to previous messageGo to next message
Actually I don't undrestand many many behaviors and things of Xtext !
For example
For a production rule like this
StyleSetting returns StyleSetting:
	'StyleSetting'
  		'fontColor' fontColor=[RGBColor]
		'backColor' backColor=[RGBColor]
why in runtime I don't have any auto completion list for fontColor
index.php/fa/24775/0/
but for backColor I have a auto completion?
index.php/fa/24776/0/
Re: Splitting a model into several files? Scoping? [message #1721438 is a reply to message #1721432] Wed, 27 January 2016 08:33 Go to previous messageGo to next message
i asume you did a manual scope adaptation. sice xtext creates objects lazy your scoping method may never be called.
=> define the scope methodlike scope_Context_referenceName(AncestorOfContext ctx, EReference r)
or change your grammar to
	{StyleSetting}'StyleSetting'
Re: Splitting a model into several files? Scoping? [message #1721446 is a reply to message #1721438] Wed, 27 January 2016 09:30 Go to previous message
I will test what you suggested later.
I didn't change or define anything because I don't know how or why should I define lazy scoping at all.
But if I change the rule to
	'StyleSetting'
		'fontColor' fontColor=[RGBColor|EString]
		'backColor' backColor=[RGBColor|EString]
I mean with EString it works perfectly !
Previous Topic:Calling parser/generator programmatically
Next Topic:global validation
Current Time: Sat Jul 26 13:20:48 EDT 2025
Powered by FUDForum. Page generated in 0.06130 seconds
