Layer usage in Sirius introduction video [message #1721352] |
Tue, 26 January 2016 13:44  |
Hi all,
in your video at https://www.eclipse.org/sirius/#manage_complexity there
is a layer named "Temperature". When this is activated additional labels
with temperature measures appear behind the unit names. How is this done?
I've tried to add an additional layer which should just contain labels
which should not be shown without this layer being activated. Within
this layer I added a container import to reference an existing element.
But it is not possible to just add labels for this element. Instead one
would need to add more container elements which seems not appropriate
for the requirement described above.
Thanks for your advice,
Axel
Re: Layer usage in Sirius introduction video [message #1721411 is a reply to message #1721408] |
Wed, 27 January 2016 04:15  |
Thanks, I will check that out.
Am 27.01.2016 um 09:56 schrieb Laurent Redor:
> Le 26/01/2016 19:44, Axel Guckelsberger a écrit :
>> Hi all,
> It is done with a "Style Customization".
> You can find the corresponding source to [1] more especially the VSM
> file [2].
>> Axel
> [1] https://github.com/ObeoNetwork/Flow-Designer
> [2]
> https://github.com/ObeoNetwork/Flow-Designer/blob/master/plugins/fr.obeo.dsl.designer.sample.flow.design/description/flow.odesign
> Regards,
FUDForum. Page generated in 0.03633 seconds
