Home » Eclipse Projects » Sirius » Style customization for edge stroke colour
Style customization for edge stroke colour [message #1721263] Tue, 26 January 2016 03:32 Go to next message
Hi all,
it seems like the stroke colour of an edge style can not be changed
using a style customization. Is this a real limitation or am I
overseeing something?
TIA
Axel
Re: Style customization for edge stroke colour [message #1721266 is a reply to message #1721263] Tue, 26 January 2016 03:50 Go to previous messageGo to next message
Hi Axel,
I have just checked on master, and a style customization affecting the
stroke color of an edge mapping seems to behave well.
Which version of Sirius do you use ?
Are you sure to have selected the good edge style ?
Is the precondition expression of your style customization ok ?
Did you activate the layer which defines the style customization ?
Le 26/01/2016 09:32, Axel Guckelsberger a écrit :
> Hi all,
> TIA
> Axel
Maxime - Obeo
Re: Style customization for edge stroke colour [message #1721276 is a reply to message #1721266] Tue, 26 January 2016 04:29 Go to previous messageGo to next message
Hi Maxime,
thanks for your quick reply.
Maybe the problem is just that the stroke colour does not appear in the
auto complete suggestions for the "Property Name" input field. The only
proposals are lineStyle, sourceArrow, targetArrow,
sizeComputationExpression, routingStyle, foldingStyle and endsCentering.
So how do I know the correct property name?
I am using Sirius 3.1.2.
Axel
Am 26.01.2016 um 09:50 schrieb Maxime Porhel:
> Hi Axel,
>> Hi all,
>> TIA
>> Axel
> Regards,
Re: Style customization for edge stroke colour [message #1721280 is a reply to message #1721276] Tue, 26 January 2016 05:08 Go to previous messageGo to next message
What I do is I change the style in a diagram manually and then look at
the saved xml file to find out how it's called.
Felix
Re: Style customization for edge stroke colour [message #1721282 is a reply to message #1721280] Tue, 26 January 2016 05:26 Go to previous messageGo to next message
Thanks, I am going to do this!
Axel
Am 26.01.2016 um 11:08 schrieb Felix Dorner:
> Felix
Re: Style customization for edge stroke colour [message #1721283 is a reply to message #1721276] Tue, 26 January 2016 05:28 Go to previous messageGo to next message
Le 26/01/2016 10:29, Axel Guckelsberger a écrit :
> Hi Maxime,
I made my sample with the completion.
The only
Ok, you have created a property customization "by Expression", which
allows you to define the new value of an attribute using the value
expression and your prefered query language.
When you have selected an edge style (Applied on), the completion in the
property name field gives you the compatible features for your current
selection and customization type:
. "by Expression": attributes
. "by Selection": references
In your case, you need to create a property customization "by Selection":
. select your edge style in the "Applied on" property
. the "Property Name" completion will propose you: strokeColor,
(begin/center/end)LabelDescription, centered(Source/Target)Mappings
. use the Value Selection combo, which suggests the known values for
the property specified in the Property Name field, to select the color
you want.
> Best regards,
> Axel
Maxime - Obeo
[1]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#customization
Re: Style customization for edge stroke colour [message #1721284 is a reply to message #1721283] Tue, 26 January 2016 05:31 Go to previous messageGo to next message
You might find more information on diagram style customizations in [1]
Maxime - Obeo
[1]
Re: Style customization for edge stroke colour [message #1721285 is a reply to message #1721283] Tue, 26 January 2016 05:45 Go to previous message
Great, thank you!
Am 26.01.2016 um 11:28 schrieb Maxime Porhel:
>> Hi Maxime,
> The only
> you want.
>> Best regards,
>> Axel
> Regards
Previous Topic:Semantic candidates/precondition expressions for mapping imports
Next Topic:Edge size not applied to decorators
Current Time: Mon Jul 21 00:32:20 EDT 2025
Powered by FUDForum. Page generated in 0.44874 seconds
