Home » Modeling » EMF » Memory Leak with TextUtils(OCL Validation / Diagnostician)
Memory Leak with TextUtils [message #1721159] |
Mon, 25 January 2016 05:39  |
I'm trying to implement some OCL validation into my RCP Application. To do so, I'm using Accuracy (a plugin that comes from KitAlpha and that allows you to register your OCLs as EMF Constraints) and I noticed that every time I called the Diagnostician from my Editor and then closed the editor, my model wasn't freed by the GC.
After futher investigation, it appeared that org.eclipse.emf.validation.internal.util.TextUtils keeps a static reference to my model's eobject.
And here is how it happens:
- AbstractOCLModelConstraint.validate calls AbstractValidationContext.createFailureStatus
- which calls TextUtils.formatMessage
- which calls TextUtils.formatScalarValue
- which calls TextUtils.getText
- which calls ComposedAdapterFactory.adapt (via its static attribute 'factory')
- which calls ComposedAdapterFactory.getFactoryForTypes
- which calls ComposedAdapterFactory.addAdapterFactory that adds my ItemProviderAdapterFactory to its 'adapterFactories' attribute.
As a result of that, I have TextUtils that has a final static reference to a ComposedAdapterFactory which contains a reference to my ItemAdapterFactory which contains a reference to my XXXItemProvider which contains a reference to my XXX eobject via its target attribute.
So my main question is : do I have a bad setup that leads to this issue, or is the static factory of TextUtils the issue here?
TextUtils.getText(EObject) line: 73
TextUtils.formatScalarValue(Object) line: 197
TextUtils.formatMessage(String, Object...) line: 161
GetBatchConstraintsOperation$1(AbstractValidationContext).createFailureStatus(Object...) line: 392
OCLConstraint(AbstractOCLModelConstraint<C,CT,CLS,E>).validate(IValidationContext) line: 162
OCLConstraint.validate(IValidationContext) line: 72
BatchValidator(AbstractValidator<T>).evaluateConstraints(AbstractValidationContext, List<IStatus>) line: 241
BatchValidator.validate(AbstractValidationContext, EObject, GetBatchConstraintsOperation, List<IStatus>) line: 264
BatchValidator.validate(ITraversalStrategy, List<IStatus>, AbstractValidationContext, Collection<EObject>, GetBatchConstraintsOperation, Set<IClientContext>) line: 211
BatchValidator.doValidate(Collection<EObject>, Set<IClientContext>) line: 149
BatchValidator(AbstractValidator<T>).validate(Collection<? extends T>) line: 147
BatchValidator(AbstractValidator<T>).validate(T) line: 126
BatchValidator.validate(EObject, IProgressMonitor) line: 117
EValidatorAdapter.validate(EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 164
Diagnostician.doValidate(EValidator, EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 171
Diagnostician.validate(EClass, EObject, DiagnosticChain, Map<Object,Object>) line: 158
Diagnostician.validate(EObject, DiagnosticChain, Map<Object,Object>) line: 137
Diagnostician.validate(EObject) line: 108
(Developping with/for Eclipse Luna)
Re: Memory Leak with TextUtils [message #1721174 is a reply to message #1721167] |
Mon, 25 January 2016 08:21  |
OK, I'll probably look stupid, but I just didn't know about the Resource.unload() method...
It seems to fix the issue, so yeah, thank you!
If it appears it doesn't solve the issue, I'll come back to this topic, but I have good hopes it's ok now.
Thanks again.
Current Time: Thu Jul 24 22:50:16 EDT 2025
Powered by FUDForum. Page generated in 0.07115 seconds
