Deploy Modeler and View Point Specification [message #1720320] |
Sat, 16 January 2016 22:51  |
Hi all,
I want to deploy Modeler and View Point Specification, which means users can double-click the icon on the desktop to start the application. The application displays only the window with section tool panel and, for example, BPMN diagram space where the elements can be dragged and dropped from the section tool panel into it.
Someone told me to export VSP as Deployable plugin and fragments. But then, how should I do? Should I write a swing code to display a window and call the plugin to display section tool panel and the diagram space inside the window? Please give me some direction.
[Updated on: Sat, 16 January 2016 22:54] by Moderator
Re: Deploy Modeler and View Point Specification [message #1720977 is a reply to message #1720320] |
Fri, 22 January 2016 04:31   |
Le 17/01/2016 04:51, Shin-Yi Lin a écrit :
> Hi all,
Hi.
> dropped from the section tool panel into the space.
> I heard someone said you can export VSP as Deployable plugin and
> fragments.
True, but in the context of Eclipse, this means "a set of plug-ins that
can be installed/deployed inside an Eclipse-based application".
> Then, how do I use the plugin and fragments? Write a swing
> panel and the space inside the window?
You'll need to create your own Eclipse-based product [1], with all the
plug-ins you want already pre-installed. This is out of the scope of
this forum, but you can find examples of Eclipse-based products done
specifically to package a Sirius-based modeler here [2] and here [3].
[2] is probably closer to what you want to achieve, as it tries to
remove/hide all the parts of Eclipse and it's UI which do not make sense
for end-users of the modeler.
Pierre-Charles
[1]
http://help.eclipse.org/mars/topic/org.eclipse.platform.doc.isv/guide/product.htm?cp=2_0_21
[2] https://github.com/mbats/arduino/wiki
[3] https://github.com/ObeoNetwork/UML-Designer
Pierre-Charles David - Obeo
FUDForum. Page generated in 0.23756 seconds
