Home » Modeling » Epsilon » [EOL/ETL] Need to determine a type of an attribute
[EOL/ETL] Need to determine a type of an attribute [message #1720770] Wed, 20 January 2016 15:39 Go to next message
Hello Folks,
I Need to determine the type of a property in a class. The type is a class also contained within my model.
The following does not work:
var p = Model!Property.all.selectOne(p|p.name = "Test");
var t = p.getEAttributeType();
Does a method exist that reads this Kind of Information?
Thanks a lot in advance and Kind regards, Alexander
Re: [EOL/ETL] Need to determine a type of an attribute [message #1720775 is a reply to message #1720770] Wed, 20 January 2016 17:07 Go to previous messageGo to next message
Dear Alexander,
I think the following code can solve your problem:
var p = Property.all.selectOne(p|p.name = "Test");
var t = p.type;
Of course, if you mean the name of the property p here, you can use the name property of type as follows:
var t = p.type.name;
Kind regards,
Alireza
Re: [EOL/ETL] Need to determine a type of an attribute [message #1720798 is a reply to message #1720775] Thu, 21 January 2016 01:53 Go to previous message
Hi Alireza,
Thanks a lot for for your reply. That worked fine.
Thanks again for your appreciated support.
Previous Topic:[EUGENIA] - Duplication Item in Connection Palette
Next Topic:EVL: Checking the existence of a relationship between two classifier
Current Time: Sun Jul 20 23:45:53 EDT 2025
Powered by FUDForum. Page generated in 0.05103 seconds
