Home » Modeling » Papyrus » Unsetting stereotype optional properties
Unsetting stereotype optional properties [message #1720735] Wed, 20 January 2016 10:03 Go to next message
Hello
I have defined stereotype in a profile with one optional integer attribute (I defined the property using the UML standard primitive integer type, and multiplicity 0..1).
Afterwards, I can apply my profile to the model, and the stereotype to an element. In the property view, in the profile panel, I can edit the property of the stereotype.
However, once I have set a value, there is no way to unset the property, I must enter an integer in the form.
Is there any way in the property view GUI to unset the property ?
The ecore editor has a button "restore default value" in the properties view header, that seems to allow this, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=222754
Another doubt, not sure if it is a Payrus or an UML2 issue :
I have checked the generated ecore, after defining the profile, and the property was converted to an EAttribute of type Integer (an EDatatype defined in the UML model library http://www.eclipse.org/uml2/5.0.0/Types#//Integer) with lower bound 0 and upper bound 1.
Why is it not converted to an unsettable attribute, to be able to distinguish the case of unset versus set to to default value ( 0 in the case of integers) ?
Re: Unsetting stereotype optional properties [message #1720812 is a reply to message #1720735] Thu, 21 January 2016 03:56 Go to previous messageGo to next message
If you want to generate more accurate Ecore definitions, you should use the Ecore profile. You can apply the EAttribute stereotype to the UML Property, and set isUnsettable=true
However, this won't be sufficient, as Papyrus doesn't implement the "unset" action for primitive type editors
Camille
Re: Unsetting stereotype optional properties [message #1721004 is a reply to message #1720812] Fri, 22 January 2016 08:29 Go to previous message
Hello
Ok, fair enough.
but then, it remains the question of whether there is some special treatment in the primitive type editors to handle attributes with multiplicity 0..1 ? or is it handled just like a multiplicity 1..1
Previous Topic:How to edit .notation file by java
Next Topic:Attention: Major API refactorings in Papyrus Neon M5
Current Time: Sat Jul 26 03:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.06834 seconds
