Home » Modeling » TMF (Xtext) » web editor with code generation
icon5.gif  web editor with code generation [message #1720470] Mon, 18 January 2016 14:45 Go to next message
I am trying to get started with a simple web editor that displays the generated language.
I have found the appropriate examples on github, like "ace-statemachine-resource", but I haven't quite figured out whats going on.
So when I start with the simple MyDsl example and implement the MyDslGenerator, how would I bind that to a web service (at /xtext-service/generate ) ?
Any help is appreciated!
Many thanks
Re: web editor with code generation [message #1720489 is a reply to message #1720470] Mon, 18 January 2016 16:45 Go to previous messageGo to next message
according to http://www.eclipse.org/Xtext/documentation/310_web_integration.html enablegeneratorService is on by default
Re: web editor with code generation [message #1720505 is a reply to message #1720489] Tue, 19 January 2016 00:48 Go to previous messageGo to next message
Here is what to todo
(1) Implement Generator
class MyDslGenerator extends AbstractGenerator {
	override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
		fsa.generateFile('/DEFAULT_ARTIFACT', 'People to greet: ' +
			resource.allContents
				.filter(typeof(Greeting))
				.map[name]
				.join(', '))
(2) Adapt Syling and UI
<html>
<head>
	<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
	<meta http-equiv="Content-Language" content="en-us">
	<title>Example Web Editor</title>
	<link rel="stylesheet" type="text/css" href="xtext/2.9.2-SNAPSHOT/xtext-ace.css"/>
	<link rel="stylesheet" type="text/css" href="style.css"/>
	<script src="webjars/requirejs/2.1.20/require.min.js"></script>
	<script type="text/javascript">
		var baseUrl = window.location.pathname;
		var fileIndex = baseUrl.indexOf("index.html");
		if (fileIndex > 0)
			baseUrl = baseUrl.slice(0, fileIndex);
		require.config({
			baseUrl: baseUrl,
			paths: {
				"jquery": "webjars/jquery/2.1.4/jquery.min",
				"ace/ext/language_tools": "webjars/ace/1.2.0/src/ext-language_tools",
				"xtext/xtext-ace": "xtext/2.9.2-SNAPSHOT/xtext-ace"
		require(["webjars/ace/1.2.0/src/ace"], function() {
			require(["xtext/xtext-ace"], function(xtext) {
				xtext.createEditor({
					baseUrl: baseUrl,
					syntaxDefinition: "xtext-resources/generated/mode-mydsl2"
					jQuery('#generate-button').bind("click", function(e){
					jQuery('#generator-result').html('<iframe src="http://' + location.host + '/xtext-service/generate?resource=example1.mydsl2"></iframe>');
					e.preventDefault();
	</script>
</head>
<body>
<div class="container">
	<div class="header">
		<h1>Example MyDsl Web Editor2</h1>
	</div>
	<div class="content">
		<div id="xtext-editor" data-editor-xtext-lang="mydsl2" data-editor-resource-id="example1.mydsl2"></div>
	</div>
	<div class="button-wrapper">
		<button id="generate-button" value="Generate" title="Generate">Generate</button>
		<div id="generator-result">
			Result
		</div>
	</div>
</div>
</body>
</html>
div.button-wrapper {
	display: block;
	position: absolute;
	top: 90px;
	bottom: 0;
	left: 640px;
	right: 0;
	padding: 4px;
	border: 1px solid #aaa;
Re: web editor with code generation [message #1720577 is a reply to message #1720505] Tue, 19 January 2016 08:24 Go to previous messageGo to next message
Yes this works. Thanks for the quick reply!
Re: web editor with code generation [message #1720660 is a reply to message #1720577] Wed, 20 January 2016 03:36 Go to previous message
As an alternative to the iframe code shown above, the generator can also be invoked with JavaScript code as described in
https://www.eclipse.org/Xtext/documentation/310_web_integration.html#invoking-services
Previous Topic:Open auto-complete without ctrl+space
Next Topic:AbstractMyDslProposalProvider
Current Time: Thu Nov 06 15:56:08 EST 2025
Powered by FUDForum. Page generated in 0.03894 seconds
