bottom up webservice tutorial with geronimo [message #172047] |
Thu, 22 June 2006 08:39  |
hi all,
I would like to ask if someone can give me a hint what I need to
consider when developing webservices on geronimo appserver.
When walking through the bottom up webservices tutorial, I got an error
at the *Service Deployement Configuration* page of the webservice
creation wizard saying " The WebSphere Application Server Community
Edition v1.0 server does not support the service project ConverterProj"
- ConverterProj is the dynamic web project containing the bean I would
like to wrap into a webservice.
After changing the service project name from ConvoerterProj to
ConverterProjWS the errormessage on the wizard disappears and after
setting the server I click finish. This results into the following error.
IWAB0398E Error in generating WSDL from Java:
java.lang.ClassNotFoundException: wtp.Converter
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:405)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at
org.apache.tools.ant.AntClassLoader.findBaseClass(AntClassLo ader.java:1197)
at
org.apache.tools.ant.AntClassLoader.loadClass(AntClassLoader .java:990)
at org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:186)
at org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:1 60)
at org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:100 )
at org.apache.axis.wsdl.fromJava.Emitter.setCls(Emitter.java:20 79)
at
org.apache.axis.tools.ant.wsdl.Java2WsdlAntTask.execute(Java 2WsdlAntTask.java:188)
at
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.executeAntTask(Java2WSDLCommand.java:163)
at
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.execute(Java2WSDLCommand.java:87)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:387)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:327)
at
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:226)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$5.run(SimpleCommandEngineManager.java:247)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:217)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:79)
at
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:228)
at
org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.performFinish(DynamicWizard.java:335)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Any ideas
Thanks Juergen
FUDForum. Page generated in 0.07163 seconds
