Home » Modeling » TMF (Xtext) » How to add formatter based on the new formatting API to the project
How to add formatter based on the new formatting API to the project [message #1720341] Sun, 17 January 2016 17:01 Go to next message
Hi, all
I have read this nice slideshare and domainmodel example provided with API, but can't understand how to add new formatter class to the eclipse infrastructure.
May somebody provide me step-by-step instruction or tutorial?
Vladimir
Re: How to add formatter based on the new formatting API to the project [message #1720345 is a reply to message #1720341] Sun, 17 January 2016 21:35 Go to previous message
Actually formatter2 support is enabled by default.
If you're using xtext 2.9.0 or 2.9.1 to generate the project, you can see the mwe2 file like this:
Workflow {
	component = XtextGenerator {
		configuration = {
			project = StandardProjectConfig {
				baseName = "org.xtext.example.mydsl"
				rootPath = rootPath
				runtimeTest = {
					enabled = true
				eclipsePlugin = {
					enabled = true
				eclipsePluginTest = {
					enabled = true
				createEclipseMetaData = true
			code = {
				encoding = "UTF-8"
				fileHeader = "/*\n * generated by Xtext \${version}\n */"
		language = StandardLanguage {
			name = "org.xtext.example.mydsl.MyDsl"
			fileExtensions = "mydsl"
			serializer = {
				generateStub = false
			validator = {
				// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
you can generate stub codes by adding the following lines under validator:
formatter = {
	generateStub = true
Previous Topic:Cross reference issue while using EmbeddedEditor
Next Topic:File Extension problems
Current Time: Mon Jul 21 02:28:53 EDT 2025
Powered by FUDForum. Page generated in 0.05375 seconds
