| database full [message #1720119] |
Thu, 14 January 2016 09:51  |
I just wanted to import my project to my production user account. Unfortunately the import fails:
Connection to Database successful.
Importing projects...
Reading projects...
Reading project file /C:/tmp/foo/myproject_1.0_20160114.xml.
Project "myproject" in version 1.0 requires the following project(s):
- project "unbound_modules_concrete" in version 8.1
Finished reading projects.
Importing myproject_1.0...
Error occurred while importing myproject_1.0:
org.eclipse.jubula.client.core.persistence.PMSaveException: Can't save project.Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.BatchUpdateException: ORA-12953: The request exceeds the maximum allowed database size of 11 GB
I already removed the test result summary but there's still no way to import it...
Do you have an idea how to get around this without reinstalling the oracle db ?
| Re: database full [message #1720219 is a reply to message #1720217] |
Fri, 15 January 2016 05:28   |
in the meantime I've fixed this.
I queried for the tablespace size as system user:
SELECT NVL(b.tablespace_name,
NVL(a.tablespace_name,'UNKOWN')) name,
round(kbytes_alloc/1024,2) Mbytes,
round((kbytes_alloc-NVL(kbytes_free,0))/1024,2) used,
round(NVL(kbytes_free,0)/1024,2) free,
round(((kbytes_alloc-NVL(kbytes_free,0))/kbytes_alloc)*100,2) pct_used
FROM ( SELECT SUM(bytes)/1024 Kbytes_free,
tablespace_name
FROM sys.dba_free_space
GROUP BY tablespace_name ) a,
( SELECT SUM(bytes)/1024 Kbytes_alloc,
SUM(maxbytes)/1024 kbytes_max,
tablespace_name
FROM sys.dba_data_files
GROUP BY tablespace_name )b
WHERE a.tablespace_name (+) = b.tablespace_name
ORDER BY PCT_USED;
NAME MBYTES USED FREE PCT_USED
UNDOTBS1 5315 34,25 5280,75 0,64
SYSAUX 790 748,13 41,88 94,7
SYSTEM 360 358,31 1,69 99,53
USERS 10610 10610 0 100
Then I saw that tablespace USERS is far too big.
Then I checked the content of tablespace USERS:
SELECT distinct owner, segment_type, segment_name
FROM dba_segments
WHERE tablespace_name='USERS';
and I saw two old project users which I deleted including data:
drop user MYUSER CASCADE;
drop user MYUSER1 CASCADE;
Afterwards I was able to import again
Next time I could shrink the tablespace USERS:
ALTER TABLESPACE USERS SHRINK SPACE KEEP 10620M;
FUDForum. Page generated in 0.15998 seconds
