Home » Eclipse Projects » Sirius » How to rearrange elements in the representation graphical view
How to rearrange elements in the representation graphical view [message #1719108] |
Tue, 05 January 2016 05:55  |
Suppose that we have an example with a semantic model (.fam) and its representation model (.aird) with multiple viewpoints.
When an element (block or container) is selected from the semantic model (.fam), we can rearrange all the sub-elements of its properties (by selecting a certain property of which is a list of elements from the Property View, then a FeatureEditorDialog will appeared with the Add, Remove, Up and Down button allowing us to rearrange these elements).
And this operation has effects on all viewpoints of the representation model immediately. We can see the changes on all instances of the modified element.
Now, suppose that we open the representation file, then open a certain viewpoint and select an element (block or container). We can rearrange graphically the sub-elements of its properties but this has no effect on the semantic model (.fam). When you reopened the example, all changes are gone because they are not saved in the semantic model.
The question is how could we rearrange the elements of properties in the representation model and update the changes to the semantic model?
Do you have any idea? Or this is simply impossible?
Thanks for your help.
Re: How to rearrange elements in the representation graphical view [message #1720084 is a reply to message #1719108] |
Thu, 14 January 2016 05:05   |
I think that what you call a viewpoint is in fact a representation.
Viewpoints are containers of representation descriptions.
Can you provide some screenshots and details of the action of
FeatureEditorDialog because I do not understand your issue what you mean
by "We can rearrange graphically the sub-elements of its properties".
If you rearrage graphically, the impact will only be on the
representation itself, therefore only the graphical model (.aird) will
be modified, not your semantic model. However, modifying the diagram
should be saved, even if there is no change on the semantic model.
Steve
> modified element.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: How to rearrange elements in the representation graphical view [message #1720131 is a reply to message #1720084] |
Thu, 14 January 2016 10:45   |
Hi Steve
Yes, you are right, I attach here an image so the problem could be illustrated more clearly.
Let's look at the Property view, we have 4 properties: Blocks list, Containers List, Description, and Name.
If you want to change the order of these 2 lists, you can do following the steps as illustrated in the picture. However, when you finish by click on the OK button:
- It seems that the data in memory is not updated to the real model
- You can see the order of elements are changed, but if you close the diagram and reopen it, everything returns to the moment before.
- As a result, you don't see the Save icon is changed, a signal to show that the model is changed, which does not happen when you modified the text properties such Description or Name.
The class of the dialog when we click the "..." button is FeatureEditorDialog.
Hope that you can see the problem in this situation.
Re: How to rearrange elements in the representation graphical view [message #1720410 is a reply to message #1720131] |
Mon, 18 January 2016 09:01  |
Thanks for the explanation and the screenshot. Can you look at the code
executed by the Ok button on FeatureEditorDialog and check that it is
executed using the editing domain of the Sirius Session?
It should probably look like this:
Session session = SessionManager.Instance.getSession(selectedElement);
session.getTransactionalEditingDomain().getCommandStack().execute(new
RecordingCommand(session.getTransactionalEditingDomain()) {
protected void doExecute() {
// Update list order
Steve
Le 14/01/2016 16:45, Thanh Liem PHAN a écrit :
> Hi Steve
Current Time: Sun Jul 27 09:44:10 EDT 2025
Powered by FUDForum. Page generated in 0.04293 seconds
