Home » Eclipse Projects » Nebula » Updating product causes artifacts problems
| Updating product causes artifacts problems [message #1705618] |
Mon, 17 August 2015 16:45  |
When I updating my product that uses Nebula widget I get the following error:
An error occurred while collecting items to be installed
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.grid,1.0.0.201508142003.
Error reading signed content:/tmp/signatureFile33130143692620178.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile33130143692620178.jar
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.grid.source,1.0.0.201508142003.
Error reading signed content:/tmp/signatureFile7737537058941296546.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile7737537058941296546.jar
Problems downloading artifact: org.eclipse.update.feature,org.eclipse.nebula.widgets.grid.feature,1.0.0.201508142003.
Error reading signed content:/tmp/signatureFile3244476115691037436.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile3244476115691037436.jar
Any ideas what causes this issue?
Alex
| Re: Updating product causes artifacts problems [message #1705621 is a reply to message #1705620] |
Mon, 17 August 2015 16:57   |
Installing from vanilla Eclipse works fine, but updating my product does not. Not sure if it helps, but both versions that I have in update site and Nebula repository are the same. May be something is wrong in my local install, but I am not sure what it is.
Also just tried to update older releases of the product to update to a newer, but not current version (for example, versions 1,2,3), so if I update from 2 to 3 I get error in my original post, but if I update from 1 to 2 I get the following error:
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.grid,1.0.0.201507082315.
Error reading signed content:/tmp/signatureFile2631476240777388709.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile2631476240777388709.jar
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.grid.source,1.0.0.201507082315.
Error reading signed content:/tmp/signatureFile3616442158019320953.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile3616442158019320953.jar
Problems downloading artifact: org.eclipse.update.feature,org.eclipse.nebula.widgets.grid.feature,1.0.0.201507082315.
Error reading signed content:/tmp/signatureFile1315231602076107400.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile1315231602076107400.jar
And I know for a fact that update form 1 to 2 was working fine before.
[Updated on: Mon, 17 August 2015 17:00] by Moderator
| Re: Updating product causes artifacts problems [message #1719755 is a reply to message #1705754] |
Mon, 11 January 2016 14:50  |
I stated having same issues with different widget, this time it's date chooser.
Whenever I try to update product to a newer version, a version that does not use date chooser, I get the following error:
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.datechooser,1.0.0.201511041902.
Error reading signed content:/tmp/signatureFile1315163590096343512.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile1315163590096343512.jar
Problems downloading artifact: org.eclipse.update.feature,org.eclipse.nebula.widgets.datechooser.feature,1.0.0.201511041902.
Error reading signed content:/tmp/signatureFile8186120701889000795.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile8186120701889000795.jar
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.datechooser.source,1.0.0.201511041902.
Error reading signed content:/tmp/signatureFile1500743330599578444.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile1500743330599578444.jar
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.formattedtext,1.0.0.201511041902.
Error reading signed content:/tmp/signatureFile1097997051656542774.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile1097997051656542774.jar
Problems downloading artifact: org.eclipse.update.feature,org.eclipse.nebula.widgets.formattedtext.feature,1.0.0.201511041902.
Error reading signed content:/tmp/signatureFile8361133969171828496.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile8361133969171828496.jar
Problems downloading artifact: osgi.bundle,org.eclipse.nebula.widgets.formattedtext.source,1.0.0.201511041902.
Error reading signed content:/tmp/signatureFile332899736244089153.jar
An error occurred while processing the signatures for the file: /tmp/signatureFile332899736244089153.jar
This time I did not go against snapshot update site, but downloaded Nebula Incubator update site zip file and hosted it on our server. If you read my previous post on this thread, you'll see that I resolved issue with grid widget by building org.eclipse.nebula.widgets.grid myself and hosting it on our server. I'd like to find out what is the cause of this issue rather than doing what I did with grid widget for date chooser.
Software works fine when I run the product version that uses date chooser, problems occurs only when I am updating from older version to newer one.
[Updated on: Mon, 11 January 2016 15:05] by Moderator
Current Time: Sun Nov 23 05:25:31 EST 2025
Powered by FUDForum. Page generated in 0.05488 seconds
