Markers & Quick-fixes in tree editor [message #1719737] |
Mon, 11 January 2016 13:04  |
I'm trying to improve the B3 editor to add features simplifying to setting of versions for features. This is tracked in https://bugs.eclipse.org/bugs/show_bug.cgi?id=485472 and dependencies.
I've currently successfully implemented some addition rules with EMF validation, managed to invoke the validation and to turn the validation breakages into markers in the IDE. However, I'm still struggling at 2 things for which I'd welcome some help. It's been a while since I've done EMF stuff, so I'm probably "rotten" on this topic, so excuse my questions if they're trivial or if I missed an obvious answer somewhere else (I tried several requests but didn't manage to reach a link with helput code snippets)
* From a given ConstraintStatus or IMarker, how can I ask the right node in the Tree-based editor to be decorated with this warning/error? I could do it with plain JFace, but I imagine there's something higher-level for that. Isn't there?
* Form a given ConstraintStatus or Marker, what is the best way to present a quick-fix? With textual editor, quickfixes appear in the left ruler, on hover and on Ctrl-1. Is there similar "standard" approach for quick-fixes in EMF-based Tree editors? What is this? Do you have a good snippet of code showing how this can work?
Re: Markers & Quick-fixes in tree editor [message #1719861 is a reply to message #1719737] |
Tue, 12 January 2016 11:21  |
Mickael,
Comments below.
On 11/01/2016 7:04 PM, Mickael Istria wrote:
I suppose it's using the extended validation framework, not just the
basic generated from EMF core...
More recent versions of EMF support generating a live validator that
decorates the tree with problem indicates, e.g., you'll see that in the
Sample Ecore Editors and in Oomph's Setup Editor if you enable Live
Validation in the menu bar for those editors.
No, I've not seen that implemented in tree based editors whether they be
ones based on EMF models or otherwise... I'm not sure how one would
present such access. If there are IMarkers, I assume they could support
such actions.
FUDForum. Page generated in 0.08935 seconds
