gef4 removing nodes from a graph does not refresh the viewer [message #1719588] |
Sat, 09 January 2016 05:32  |
I have a adapted the CustomNodeExample to provide context menu for a graph.
I observe, that the graph won't get refreshed, if I only remove nodes and edges, however if I add a node, the graph view does get refreshed.
Here is the code, that changes the contents of the graph
private static NodeContextMenuEntry includes(Scope scope)
return new NodeContextMenuEntry("show includes", "hide includes")
protected void offAction(Graph graph, Node scopeNode)
WorkflowScopeNodeModel scopeNodeModel = (WorkflowScopeNodeModel) NodeModel.get(scopeNode);
List<Node> nodes = graph.getNodes();
ListIterator<Node> nodeIter = nodes.listIterator();
Node hack = null;
while (nodeIter.hasNext())
Node n = nodeIter.next();
if (scopeNodeModel.includeNodes.contains(n))
hack = n;
nodeIter.remove();
ListIterator<Edge> edgeIter = graph.getEdges().listIterator();
while (edgeIter.hasNext())
Edge e = edgeIter.next();
if (scopeNodeModel.includeEdges.contains(e))
edgeIter.remove();
// this is a hack - I have no idea, why removing does not update the graph whereas adding does.
if(null != hack)
{nodes.add(hack);nodes.remove(hack);}
protected void onAction(Graph graph, Node scopeNode)
for (Node n : scopeNodeModel.includeNodes)
nodes.add(n);
List<Edge> edges = graph.getEdges();
for (Edge e : scopeNodeModel.includeEdges)
edges.add(e);
If you cannot reproduce the behaviour, I'll post a more complete example.
Arne
FUDForum. Page generated in 0.03017 seconds
