Home » Newcomers » Newcomers » The Problems/Questions about compiling eclipse from source(build problem)
The Problems/Questions about compiling eclipse from source [message #1719671] Mon, 11 January 2016 04:56 Go to next message
Hi all,
I'm trying to utilize the build system embedded in android(aka. output an ADT-integrated eclipse). But met some errors (see attachment 'workspace.metadata.log' ):
Q:
1. Are these the root cause: "Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.0))(&(osgi.ee=JavaSE)(version=1.3)))"" ??
2. I notice three places provide similar .jar(s):
a) eclipse.platform.releng.basebuilder
b) The deltapack
c) The org.eclipse.platform tarball - part of SDK source
Are they involved in different building stages? (How?) For my problem, only a) is related?
Following is the snippet of build.xml (used by the Makefile as "java -jar /path/to/org.eclipse.equinox.launcher_xxx.jar ")
<target name="product-build" depends="feature-build">
<java classname="org.eclipse.equinox.launcher.Main" fork="true" failonerror="true">
<arg value="-application" />
<arg value="org.eclipse.ant.core.antRunner" />
<arg value="-buildfile" />
<arg value="${pde.build.dir}/scripts/productBuild/productBuild.xml" />
<arg value="-data" />
<arg value="${productBuildDir}/workspace" />
<arg value="-configuration" />
<arg value="${productBuildDir}/configuration" />
<arg value="-Dtimestamp=${timestamp}" />
<arg value="-DeclipseLocation=${baseBuilder}" />
<arg value="-DbuildDirectory=${productBuildDir}" />
<arg value="-DbaseLocation=${targetDir}/deltapack/eclipse" />
<arg value="-DrepoBaseLocation=${targetDir}/repos/" />
<arg value="-DtransformedRepoLocation=${targetDir}/transformedRepos/" />
<arg value="-Dconfigs=${buildconfigs}" />
<arg value="-DforceContextQualifier=${QUALIFIER}" />
<classpath>
<pathelement location="${equinox.launcher}" />
</classpath>
</java>
</target>
Any idea?
Thanks.
Re: The Problems/Questions about compiling eclipse from source [message #1720503 is a reply to message #1719671] Tue, 19 January 2016 00:26 Go to previous message
This log file is for an ancient version of Eclipse being run with an already end-of-lifed version of Java.
What build system are you talking about? Which similar jars are you talking about?
Previous Topic:Eclipse sees Angularjs plugin but not Tern
Next Topic:Problem Opening Wizard - Plug-in Development
Current Time: Sat Nov 08 23:32:19 EST 2025
Powered by FUDForum. Page generated in 0.09624 seconds
