Home » Newcomers » Newcomers » FindBugs(FindBugs does not load)
FindBugs [message #508506] Tue, 19 January 2010 04:31 Go to next message
Dear all,
I have installed Eclipse Galileo under Fedora 12, and today I tried to install the FindBugs plugin using the update manager with url http://findbugs.cs.umd.edu/eclipse.
Checking the installed software I'm informed that FindBugs feature 1.3.9.20090821 is installed. Looks ok to me...
However, after restarting Eclipse FindBugs does not show up in my project properties. Also not in context-menu on pacakges in project explorer.
Maybe it is not able to load for some reason. Where can I find a plugin logfile or something?? My error log does not say anything about the FindBugs plugin.
Jeebee
Re: FindBugs [message #509010 is a reply to message #508506] Thu, 21 January 2010 01:11 Go to previous messageGo to next message
maybe this helps: http://www.vogella.de/articles/Findbugs/article.html
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
On 19.01.2010 01:31, Jeebee wrote:
> Dear all,
> explorer.
> FindBugs plugin.
> Jeebee
Re: FindBugs [message #509356 is a reply to message #509010] Fri, 22 January 2010 03:50 Go to previous messageGo to next message
No. Thanks, but that does not help.
The problem is that, right at step 2.2 at your link, I do not have the FindBugs item in the left panel.
That made me think FindBugs does not get loaded correctly.
Kind regards,
JeeBee
Re: FindBugs [message #509480 is a reply to message #509356] Fri, 22 January 2010 09:55 Go to previous messageGo to next message
I would assume that Findbugs is then not installed correctly. You might
want to try the Findbugs mailing list for advice.
> JeeBee
Re: FindBugs [message #825451 is a reply to message #509356] Tue, 20 March 2012 17:20 Go to previous messageGo to next message
Were you able to resolve the problem of findbugs not appearing in Eclipse . I was able to get it on right click for the first time then I changed the view in Eclipse and from that point onwards whenever I right click on the project or packages I am not able to get the findbugs option.
Sachin.
Re: FindBugs [message #1719192 is a reply to message #508506] Wed, 06 January 2016 01:00 Go to previous messageGo to next message
Hi I have installed FindBugs plug-in. I can see option FindBug in properties. Even code contains bugs, its not listing under Bug info.
My code contains,
String aString = "bob";
b.replace('b', 'p');
if(b.equals("pop")){
System.out.println("done");
where i should get error at line "b.replace();", I am not finding this in bug info window.
javascript: insertTag(document.post_form.msg_body, 'index.php/fa/24499/0/', '');
javascript: insertTag(document.post_form.msg_body, 'index.php/fa/24500/0/', '');
Re: FindBugs [message #1719266 is a reply to message #1719192] Wed, 06 January 2016 11:49 Go to previous message
> My code contains,
> javascript: insertTag(document.post_form.msg_body, '');
I don't think you should expect to get an answer in this forum. FindBugs
is a plug-in for Eclipse, but not by Eclipse. You'll want to look
elsewhere for support, maybe stackoverflow.com.
Previous Topic:Eclipse 4.5 update sites: Page not found
Next Topic:Problem with color themes
Current Time: Sun Jul 27 09:58:24 EDT 2025
Powered by FUDForum. Page generated in 0.11737 seconds
