Luna on RHEL 6: unable to read repository at ~/.eclipse [message #1719056] |
Mon, 04 January 2016 13:27  |
I'm trying to use the Eclipse Marketplace to install a plugin (though I have the same problem whether I go through Marketplace or 'Install New Software...'), and while the IDE appears to successfully retrieve information describing which features the plugin includes, when I try to start the installation I get this error:
Unable to read repository at file:/home/hoobajoob/.eclipse/org.eclipse.platform_4.4.2_1473617060_linux_gtx_x86_64/p2/org.eclipse.equinox.p2.repository/cache/compositContent1862373669.jar
invalid entry CRC (expected 0xf8fe8221 but got 0xd5b3b444)
I have installed this same plugin using the same version of Eclipse on Windows without any problems, so I don't believe there is anything at all wrong with the plugin (fwiw, it's the Gradle Buildship plugin you find when you search for 'buildship' on the Eclipse Marketplace within Eclipse).
Any ideas how to fix this?
[Updated on: Mon, 04 January 2016 13:27] by Moderator
FUDForum. Page generated in 0.12491 seconds
