Home » Newcomers » Newcomers » Eclipse Job custom ProgressMonitorDialog instance
Eclipse Job custom ProgressMonitorDialog instance [message #1718762] Tue, 29 December 2015 17:23 Go to next message
I have the following problem:
I am starting my script as an eclipse job (org.eclipse.core.runtime.jobs.Job). I now want the job to cancel immediatly (interupt/stop the thread) when the user clicks on the cancel button. This is important to me, since i have very time intensive calls to external APIs which means the normal approach of polling the monitor.isCancelled() flag is not really applicable for me. My idea here is to run the job with a custom ProgressMonitorDialog, that overrides the cancelPressed() method. But how do i start a job with a custom ProgressMonitorDialog? Or is there an easier approach?
Greetings,
Simon
PS: I have no idea where this post belongs, i hope this isn't tooo wrong Razz
Re: Eclipse Job custom ProgressMonitorDialog instance [message #1718770 is a reply to message #1718762] Tue, 29 December 2015 22:12 Go to previous messageGo to next message
On 12/29/2015 03:23 PM, Simon Eismann wrote:
> Hello,
> Greetings,
> Simon
> PS: I have no idea where this post belongs, i hope this isn't tooo wrong :p
Simon,
This is the place. Someone will be along shortly.
Cheers
Re: Eclipse Job custom ProgressMonitorDialog instance [message #1718774 is a reply to message #1718762] Wed, 30 December 2015 00:23 Go to previous messageGo to next message
Simon,
Perhaps an easier approach would be to have your job's run method create
a thread that polls the monitor's isCancelled state, with short
Thread.sleeps to keep it waiting relatively non-busy. When it detects
that isCancelled becomes true, you can do what you need to do to
interrupt the job's thread. You'll want to be sure to stop such a
thread if the job completes normally.
On 29/12/2015 11:23 PM, Simon Eismann wrote:
> Hello,
> an easier approach?
> Greetings,
> Simon
> wrong :p
Re: Eclipse Job custom ProgressMonitorDialog instance [message #1718841 is a reply to message #1718774] Wed, 30 December 2015 20:49 Go to previous messageGo to next message
Hey Ed,
Your solution worked beautifully. My setup looks like this now:
public class CancelableEngineJob extends Job {
	private boolean done = false;
	protected IStatus run(IProgressMonitor monitor) {
        Thread t = new Thread(new WorkThread(monitor, this));
		done = false;
        t.start();
        while (!monitor.isCanceled() && !done) {
        	try { Thread.sleep(500); } catch (InterruptedException e) {}
		return Status.OK_STATUS;
	public void notifiyWorkIsDone() {
		done = true;
and
class WorkThread implements Runnable {
	private IProgressMonitor monitor;
	private CancelableEngineJob job;
	public WorkThread(IProgressMonitor monitor, CancelableEngineJob job) {
		this.monitor = monitor;
		this.resource = resource;
		this.job = job;
	public void run() {
		... do api cals
		notifyAboutFinish(listeners);
	private void notifyAboutFinish() {
		monitor.done();
		job.notifiyWorkIsDone();
Which creates lightningfast responses to the cancel button, no matter what i do inside the workthread Smile Thank you for your help
Re: Eclipse Job custom ProgressMonitorDialog instance [message #1718852 is a reply to message #1718841] Thu, 31 December 2015 02:13 Go to previous message
Simon,
It's very nice of you to share your implementation! Happy New Year. :-)
On 31/12/2015 2:49 AM, Simon Eismann wrote:
> Hey Ed,
> @Override
> done = false;
> t.start();
> done = true;
> and
> job) {
> this.job = job;
> @Override
> public void run() {
> ... do api cals
> monitor.done();
> what i do inside the workthread :) Thank you for your help
Previous Topic:Can't install any plugins
Next Topic:comment on the same line as code
Current Time: Fri Jul 25 09:54:52 EDT 2025
Powered by FUDForum. Page generated in 0.08541 seconds
