Home » Newcomers » Newcomers » Can't install any plugins(java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty)
Can't install any plugins [message #1718767] Tue, 29 December 2015 19:52 Go to next message
Fought with this all night and tried pretty much everything. About to lose hope and switch to IntelliJ, as the plugins are what keep Eclipse a top choice for me.
Unable to read repository at https://raw.github.com/mystilleef/eclipse-smartclose-updatesite/master/com.laboki.eclipse.updatesite.smartclose/content.xml.
java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
I'm running
Ubuntu 15.10
java version "1.8.0_66" (oracle)
Eclipse IDE for Java Developers
Version: Mars.1 Release (4.5.1)
Build id: 20150924-1200
This is the vm args part of my eclipse.ini
-vmargs
-Dosgi.requiredJavaVersion=1.8
-XX:MaxPermSize=256m
-Xms256m
-Xmx2048m
-javaagent:/home/jp/eclipse/lombok.jar
-Djava.net.preferIPv4Stack=true
-Djavax.net.ssl.trustStore=/etc/ssl/certs/java/cacerts
Added the last 2 lines after googling this issue, no other changes in eclipse.ini.
This is a rather fresh install. Before I tried to install any plug ins, I tried to use java 9 early access, but that caused lot of issues so fell back to java 8. So the java9 install might have fucked some certs up or someting, although I did do my best to rule that out.
So far I have tried:
- Removing all instances of java and installing JDK8.
- sudo update-ca-certificates -f
- sudo apt-get install --reinstall ca-certificates-java
- doing the 2 above again after I had manually deleted /etc/ssl/certs/java/cacerts
Re: Can't install any plugins [message #1718772 is a reply to message #1718767] Tue, 29 December 2015 23:10 Go to previous messageGo to next message
Is it a problem for any plug-in as the subject says, or just the "Smart Close" plug-in?
Re: Can't install any plugins [message #1718776 is a reply to message #1718767] Wed, 30 December 2015 00:33 Go to previous message
Seppo,
When I open that link in the browser, it looks like this is not well
formed xml. Looking at the source of that page, it looks as if it's
just the string "Not Found". So something isn't right about this site.
> I'm running Ubuntu 15.10
> -vmargs
> -Xms256m
> -Xmx2048m
> eclipse.ini.
Previous Topic:Uninstall Eclipse Mars
Next Topic:Eclipse Job custom ProgressMonitorDialog instance
Current Time: Fri Jul 25 17:32:20 EDT 2025
Powered by FUDForum. Page generated in 0.09844 seconds
