| Anchorage points on SVG elements [message #1717906] |
Thu, 17 December 2015 11:25  |
I'm working on an Eclipse RCP project with Sirius and i want to know if it's possible to set anchorage points on SVG elements.
The main goal is to connect links at predefined points on a graphical element.
Thanks.
| Re: Anchorage points on SVG elements [message #1718682 is a reply to message #1718656] |
Tue, 29 December 2015 03:16   |
From Sirius 3.0 it is possible, see [1].
If you cannot do it, could you provide an example with scenario or a
little screencast?
[1] http://cedric.brun.io/eclipse/sirius-3.0M6-anchors/
Le 28/12/2015 19:58, Jonathan Dumont a écrit :
> In fact, we want to force the link connection on some specific locations
> on the edge. For example, if you have a triangle in SVG, we want to
> force the link to be connected on the apex only, or only on the middle
> of the segments.
> Is this possible, by modifying the SVG format ? Or programmatically,
> even after the link creation ?
> Regards,
> Jonathan
Esteban Dugueperoux - Obeo
| Re: Anchorage points on SVG elements [message #1718684 is a reply to message #1718682] |
Tue, 29 December 2015 03:29   |
To do it programmatically after edge creation, you must modify the
org.eclipse.gmf.runtime.notation.Anchor of the GMF Edge.
Best Regards.
> little screencast?
>> Hi,
>> of the segments.
>> Regards,
>> Jonathan
| Re: Anchorage points on SVG elements [message #1718726 is a reply to message #1718723] |
Tue, 29 December 2015 08:15  |
Ok I understand better, the layout of the edge depends of the router
used, the bendpoints and the anchors defined in the notation model. The
router can be defined in the odesign model and can be customized in the
diagram editor through the tabbar or properties view. For example the
tree router could be useful for your need. In addition in odesign model,
you can use "Ends Centering" property available on Edge Style to have
always the edge centered on source, target or both.
Best Regards.
Le 29/12/2015 13:49, Jonathan Dumont a écrit :
> We are using Sirius 3.x and what is described in this example works correctly : the transparent pixels are not considered as the path of the shape. But this is not what I need. To continue with the given example, what I need is to force the link to be connected with the left and right apex (in the red circles in my picture). Is it possible by modifying the SVG shape properties ? Or to define the anchors in the odesign model ?
> Regards,
> Jonathan
FUDForum. Page generated in 0.04157 seconds
