Mars.1 (4.5.1 ) Build id: Z20151207-1411 problems [message #1718564] |
Sun, 27 December 2015 05:32  |
I recently upgraded my system and among the updates was a switch to
Version: Mars.1 (4.5.1) Build id: Z20151207-1411
from an earlier Mars.1 build (I don't know which one).
There were several problems, some which eventually corrected themselves
However, there are a few that I'd like to overcome.
Issue #1: excessive CPU use
There is constant CPU usage. Approx 30-40%. It's worse when Eclipse has focus. Can anybody tell me what it's doing?
EDIT: added this image of top output while Eclipse has focus. As you can see instead of just sitting quietly it's burning almost 100% of the thread time.
issue #2: colors
I had to import syntax colors from a previous setting. This is OK but seems it should have been unnecessary.
The foreground/background color for many views and dialogs abruptly changed to light gray on white. It used to be white on black. I'd like to change these back to what the previous version had but I can't find any settings to change They are impossible to read.
Here are a couple of examples.
Issue #3: Builds, Runs, Debugs
Building takes a long time to actually start. Even for a build that has nothing to do, there is a period of minutes before it starts. I use my own makefile so I don't see any reason for the delay. Nothing appears in the Progress View. After a long delay, the Progress view shows several steps during the build which rapidly disappear. There is a lot of CPU usage during the delay -- approaching 100%.
The delay also happens before a Run or Debug Launch.
The delay is more than annoying. It make Eclipse useless for anything outside of editing.
If these can't be resolved I'd like to revert back to the previous build version but I'm not sure what I would need to do to make this happen.
EDIT
It's occurred to me that I should contact the builders of the update package. The URL given in the description (using DNF under Fedora) is eclipse.org. Are the packages maintained by Eclipse or is there someone else in the path? Does anyone know? It seems this should be a bug report but I don't know where to submit it. Eclipse? Fecora? Does it matter?
Attachment: PrbView.png
(Size: 10.78KB, Downloaded 1308 times)
Attachment: PrfDialog.png
(Size: 31.03KB, Downloaded 1394 times)
Attachment: TopImage.png
(Size: 53.10KB, Downloaded 1290 times)
[Updated on: Sun, 27 December 2015 16:56] by Moderator
Re: Mars.1 (4.5.1 ) Build id: Z20151207-1411 problems [message #1718571 is a reply to message #1718564] |
Sun, 27 December 2015 08:27  |
FWIW: I reverted to an earlier build
Version: Mars.1 Release (4.5.1)
Build id: 20150924-1200
Part of the upgrade was a change to GCC 5.3.1 while the previous version was 5.1.so I had to run the indexer on all projects but at least I got back to something useful.
Could be the upgrade has a bug or something I had installed had a compatibility issue with the new release.
There are still some issues with the Dark theme in Eclipse but they are nothing compared to what I've just experiences.
If anyone has suggestions about how to fix the above problem I'd like to hear them. I have the new version installed on another machine so debugging is still an option.
FUDForum. Page generated in 0.05176 seconds
