| NullPointerException during programmatically generation of diagram Images [message #1718384] |
Wed, 23 December 2015 03:30  |
i am trying to generate Images of programmatically generated diagrams. I have Rectangles with rounded corners and during the paint methods sub calls the image creation fails.
I think it fails because the OneLineMarginBorder objects int[] dash attribute is a null reference.
Is this a bug? Is there any workaround to avoid this?
Best regards
Mehmet Karaman
at org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.graphics.GraphicsToGraphics2DAdaptor.setLineDash(GraphicsToGraphics2DAdaptor.java:1124)
at org.eclipse.gmf.runtime.draw2d.ui.internal.graphics.ScaledGraphics.setLineDash(ScaledGraphics.java:802)
at org.eclipse.sirius.diagram.ui.tools.api.figure.OneLineMarginBorder.paint(OneLineMarginBorder.java:56)
at org.eclipse.sirius.diagram.ui.tools.internal.figure.RoundedCornerMarginBorder.paint(RoundedCornerMarginBorder.java:67)
at org.eclipse.draw2d.Figure.paintBorder(Figure.java:1137)
at org.eclipse.draw2d.Figure.paint(Figure.java:1121)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1170)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1205)
at org.eclipse.draw2d.Figure.paint(Figure.java:1120)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1200)
at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:160)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1209)
at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.paintFigure(DiagramGenerator.java:373)
at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.renderToGraphics(DiagramGenerator.java:226)
at org.eclipse.gmf.runtime.diagram.ui.render.clipboard.DiagramGenerator.createSWTImageDescriptorForParts(DiagramGenerator.java:721)
at org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil.copyToImage(CopyToImageUtil.java:376)
at org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUtil.copyToImage(CopyToImageUtil.java:305)
... 127 more
FUDForum. Page generated in 0.03585 seconds
