Home » Modeling » QVT-OML » [QVTo] Transform an object by a condition.
[QVTo] Transform an object by a condition. [message #1718355] Tue, 22 December 2015 15:01 Go to next message
Can I reference an object in a mapping from another mapping?
I need transform an object consulting an object in another mapping.
Thanks.
Re: [QVTo] Transform an object by a condition. [message #1718372 is a reply to message #1718355] Wed, 23 December 2015 01:17 Go to previous messageGo to next message
The easiest way is to share the object is via a parameter. However if
it's a generated object you need to use 'resolve'.
The specification/description of 'resolve' is much improved in QVT 1.3
(approved but not yet released). See 8.1.11 of
http://www.omg.org/cgi-bin/doc?ptc/15-10-02
Beware, most of the changes in QVT 1.3 are clarification of vagueness
that Eclipse QVTo already implements, however some clarifications are
not yet implemented by Eclipse QVTo, so don't push into dark corners.
Ed Willink
On 22/12/2015 20:01, Gonzalo Bressan Zuber wrote:
> Thanks.
Re: [QVTo] Transform an object by a condition. [message #1718429 is a reply to message #1718372] Wed, 23 December 2015 10:07 Go to previous messageGo to next message
Hi Ed,
The object belongs to a source model.
How use the arguments?
Thanks.
Re: [QVTo] Transform an object by a condition. [message #1718443 is a reply to message #1718429] Wed, 23 December 2015 12:36 Go to previous messageGo to next message
How understand question? https://wiki.eclipse.org/OCL/ForumNetiquette
On 23/12/2015 15:07, Gonzalo Bressan Zuber wrote:
> Hi Ed,
> Thanks.
Re: [QVTo] Transform an object by a condition. [message #1718451 is a reply to message #1718443] Wed, 23 December 2015 17:25 Go to previous messageGo to next message
Sorry if I did not express well.
I'll try again:
In this case, i'm working in a following mapping of the transformation
mapping java::InfixExpression::ie2ie() : java::InfixExpression {
operator := self.operator;
comments := self.comments -> com2com();
originalCompilationUnit := self.originalCompilationUnit.map cu2cu();
originalClassFile := self.originalClassFile.map cf2cf();
rightOperand := self.rightOperand.map ex2ex();
leftOperand := self.leftOperand.map ex2ex();
extendedOperands := self.extendedOperands -> ex2ex();
I need to transform the object "operator" belonging to ie2ie mapping if exists a comment equal to "//mutate" in the java program in the same line that an infix expression.
You understande me now?
Thanks.
Re: [QVTo] Transform an object by a condition. [message #1719493 is a reply to message #1718451] Fri, 08 January 2016 05:52 Go to previous message
I'll try again too: https://wiki.eclipse.org/OCL/ForumNetiquette
> I'll try again:
> Thanks.
Previous Topic:QVTo Trace Editor doesn't show properties of elements
Next Topic:Keeping xmi:id for migration
Current Time: Sat Jul 19 03:09:34 EDT 2025
Powered by FUDForum. Page generated in 0.28655 seconds
