Home » Newcomers » Newcomers » Using New Installer on Mac(Incompatible JVM Problem)
Using New Installer on Mac [message #1717586] Tue, 15 December 2015 00:29 Go to next message
In trying to use the Eclipse Installer on a Powerbook Pro running OS X 10.11.1,
I get the message "Incompatible JVM" with details: "Version 1.6.0_65 of JVM not suitable, 1.7 or greater rerquired".
Any suggestions on how the issue can be resolved would be appreciated. Thanks.
Re: Using New Installer on Mac [message #1717665 is a reply to message #1717586] Tue, 15 December 2015 10:42 Go to previous messageGo to next message
> 10.11.1,
> Thanks.
Not a Macintosh guy, but wouldn't this just mean it's time to bump your
JRE to a modern one? The current Oracle JRE is at 1.8. 1.6 and 1.7
aren't really supported anymore. (Apple may be different on this point,
I don't know.)
Re: Using New Installer on Mac [message #1717765 is a reply to message #1717665] Wed, 16 December 2015 10:15 Go to previous messageGo to next message
David,
Did OS X prompt you to install "legacy" Java (1.6) when you tried to run the Eclipse installer the first time? I've seen several reports of that here and on Stack Overflow and I wonder if the Installer/Oomh team are aware of the problem.
Re: Using New Installer on Mac [message #1717787 is a reply to message #1717586] Wed, 16 December 2015 12:02 Go to previous messageGo to next message
David,
google for 'oracle java os x', go to the Oracle download page so found (the page address is built on the fly, so I don't give a direct link).
Select Java SE SDK 8u66 for OS X and install it from the downloaded .dmg following the Oracle instructions (nothing fancy, just a normal dmg install), and try the Mars installer again.
It works here on OS X 10.9.5 without any problems.
Re: Using New Installer on Mac [message #1717837 is a reply to message #1717765] Thu, 17 December 2015 03:54 Go to previous messageGo to next message
Am 16.12.2015 um 16:15 schrieb Eric Rizzo:
> David,
Only for Windows we provide a special native executable that can do better than the Platform's launcher when it comes to
JVM detection and validation. We'd like to provide these enhancements for the other OSs, too, but that is quite some
effort and it's currently not high on our list of things to do. We track it here:
477998: Installer artifact for MacOS should be a .dmg or .app instead of .tar.gz
https://bugs.eclipse.org/bugs/show_bug.cgi?id=477998
Meanwhile Mac and Linux users will experience the same problems as they would when starting an Eclipse IDE directly.
Cheers
/Eike
http://www.esc-net.de
Re: Using New Installer on Mac [message #1717871 is a reply to message #1717837] Thu, 17 December 2015 08:27 Go to previous messageGo to next message
Eike,
Are you aware that on recent versions of OS X the Oomph installer doesn't work if the user doesn't already have a JDK (not JRE) installed? They get the "legacy Java" message from OS X, but if they install that (it's Java 1.6) then the Oomph installer will run but complain that they require Java 1.7. It's a frustrating dead-end for users.
Seems like it would be worthwhile to investigate why OS X insists that the Oomph executable requires "legacy Java."
[Updated on: Thu, 17 December 2015 08:28] by Moderator
Re: Using New Installer on Mac [message #1717886 is a reply to message #1717871] Thu, 17 December 2015 09:02 Go to previous messageGo to next message
Eric,
Eike and I are both Windows users though we have virtual boxes for Mac
and Linux (Ubuntu). My Mac virtual box is unfortunately broken again.
So it's hard for us to experience the behavior of recent versions of OS
X. One has to wonder why a recent version of OS X doesn't come with a
decently recent version of Java, but that's hardly something any of us
can influence...
In any case, the behavior of the Eclipse native launcher on all the
platforms is arguably poor when the necessary version of Java of the
correct bitness isn't available. So on Windows we provide our own
native executable for launching the installer, which does a proper job
of figuring out which JVMs are available (even if they aren't on the
PATH), and properly prompts the user to install an appropriate JRE/JDK
when necessary. If we distributed the installer on Mac as a DMG and
provided a similar native executable with similar behavior to Windows,
we could definitely improve this situation. Failing that, we're stuck
with an ugly tar file and stuck with the Eclipse native launcher, along
with its associated nasty misbehavior. We're very sorry for that, but
the weeks of effort involved in improving this, working on a horrible
virtual box, is just not something we can manage...
On 17/12/2015 2:27 PM, Eric Rizzo wrote:
> Eike,
> users.
Re: Using New Installer on Mac [message #1717903 is a reply to message #1717871] Thu, 17 December 2015 11:04 Go to previous messageGo to next message
Am 17.12.2015 um 14:27 schrieb Eric Rizzo:
> Eike,
No, I wasn't aware of this "legacy Java" message from OS X. I wonder what would happen on those systems if the user
didn't use the installer but jutst unzipped a Mars package that requires Java 1.7?
Cheers
/Eike
Re: Using New Installer on Mac [message #1717907 is a reply to message #1717903] Thu, 17 December 2015 11:26 Go to previous messageGo to next message
Eike Stepper wrote on Thu, 17 December 2015 16:04
> Eike,
I bet it does the same, based on some reports from StackOverflow:
http://stackoverflow.com/a/19594116/639520
http://stackoverflow.com/q/26721749/639520
http://stackoverflow.com/q/26847411/639520
I don't have the newest versions of OS X on my MacBook so I can't verify myself, but there are quite a few reports of this on both SO and the Eclipse forums.
Re: Using New Installer on Mac [message #1718064 is a reply to message #1717586] Fri, 18 December 2015 15:26 Go to previous messageGo to next message
I'm so inexperienced that I haven't reached the noobi rank yet! But I also experienced the same "legacy" dialog yesterday attempting to install/run Eclipse/Mars.1 (OS X 10.10 with Java 8[?] already installed). I finally managed to get things to run by downloading " Java SE Development Kit 7u79" from here: oracle.com/technetwork/java/javase/downloads/jdk7-downloads-1880260.html [sorry, can't make this a link yet, this is my first message]You will have to click the "Agree" to the license radio button first, BTW.
Hope that help you, David]. But I also wish the rest of the install/usage were as easy. Rolling Eyes
Re: Using New Installer on Mac [message #1718077 is a reply to message #1717907] Fri, 18 December 2015 22:04 Go to previous message
Were the suggestions really worked? I want to try them. Thanks.
Previous Topic:Java mewbe/student - ms sql connectionstring login failed for user
Next Topic:Coming in COLD
Current Time: Thu Jul 24 23:00:24 EDT 2025
Powered by FUDForum. Page generated in 0.14122 seconds
