Home » Eclipse Projects » e(fx)clipse » trouble restarting e4+javafx application(can't restart tycho built e4+javafx application )
trouble restarting e4+javafx application [message #1717998] Fri, 18 December 2015 08:26 Go to next message
Hello everyone,
So I'm working on this project and I'm trying to add p2 update functionnality to an e4+javafx application. Everything works fine until the part where I need to restart my application to reflect the changes made to the application model. The application closes, and then simply doesn't restart.
I was able to link this issue to something (no idea what exactly) related to the tycho/maven I used to build my application. See, when I use the eclipse PDE build for the export, everything works fine, I'm able to restart a dummy sample app. I simply add a Main Menu the application model, then a Menu (named File) > then a handled MenuItem (named Restart), handled by some RestartHandler.java class looking like this
import org.eclipse.e4.core.di.annotations.Execute;
import org.eclipse.e4.ui.workbench.IWorkbench;
public class RestartHandler {
	@Execute
	public void execute(IWorkbench workbench) {
	    workbench.restart();
but the the same dummy app when generated by the tycho build will simply close and won't restart. I'm I missing something here? Any suggestions?
Re: trouble restarting e4+javafx application [message #1717999 is a reply to message #1717998] Fri, 18 December 2015 08:30 Go to previous messageGo to next message
I am not sure about Tycho, but you can use the efxclipse RestartService to restart the application.
	@Execute
	public void execute(RestartService restartService) {
		restartService.restart(false);
Re: trouble restarting e4+javafx application [message #1718000 is a reply to message #1717998] Fri, 18 December 2015 08:40 Go to previous messageGo to next message
So when you export via tycho, how do you launch it? Via java -jar? Using
the javafx-packager generated .exe?
Tom
On 18.12.15 14:26, Paul Mira wrote:
> Hello everyone,
> doesn't restart.
> this
> @Execute
Re: trouble restarting e4+javafx application [message #1718002 is a reply to message #1717999] Fri, 18 December 2015 08:46 Go to previous messageGo to next message
No luck, same result
Re: trouble restarting e4+javafx application [message #1718003 is a reply to message #1718000] Fri, 18 December 2015 08:56 Go to previous messageGo to next message
after generated via tycho I launch it using the generated .exe
The whole thing is really simple to reproduce, just build a sample e4-javafx app structure using the "JavaFX > Osgi > e4 application project" new project wizard. Add a simple main menu > menu > handled menu item to the application model, create a command+handler for it, and use the simple RestartHandler.java class I gave for the handler.
Then build the whole thing with tycho and see if the app restarts when you click on that menu item
I'm working on Eclipse 4.5.1 (Mars) M20150904-0015, with efxclipse -IDE 2.1.0
[Updated on: Fri, 18 December 2015 08:58] by Moderator
Re: trouble restarting e4+javafx application [message #1718061 is a reply to message #1718003] Fri, 18 December 2015 13:50 Go to previous messageGo to next message
So thanks again everyone, I got a hunch from this Tom's advice
If you are targeting Linux & Windows just check the include native
launcher artifacts, fix the p2-repos in your tycho build to include
those natives, fix the platform-section and run tycho.
which he gave here : https://www.eclipse.org/forums/index.php/t/1000801/
so what I did precisely (for anyone interested) is configure my parent pom.xml (in the releng project) and changed the target-platform-configuration related plugin. So I replaced this
<environments>
						<environment>
							<os>noenv</os>
							<ws>noenv</ws>
							<arch>noenv</arch>
						</environment>
					</environments>
with this
<environments>
						<environment>
							<os>win32</os>
							<ws>win32</ws>
							<arch>x86_64</arch>
						</environment>
					</environments>
Then I did the same in the build.xml ant file (also in the releng project) and replaced
/noenv/noenv/noenv
by
/win32/win32/x86_64
in the values of eclipse-app-dir property and equinox-launcher dir.
Then I checked "The product includes native launcher artifacts" in the product config file.
The tycho built app restarts just fine now.
So now I guess my app uses "native launchers", and can't be used on a different system. Suits me fine at this point, but I think there should be a more multi-system solution to this.
Re: trouble restarting e4+javafx application [message #1718147 is a reply to message #1718003] Sun, 20 December 2015 13:36 Go to previous messageGo to next message
The exe you talk about is generated by the java-packager and it is quite
likely that it does not support the restart!
Tom
Re: trouble restarting e4+javafx application [message #1718148 is a reply to message #1718061] Sun, 20 December 2015 13:37 Go to previous message
Right now the exe it the one from Eclipse, which works fine on windows
but fails on OS-X because JavaFX does not get a hand on the event loop.
Tom
On 18.12.15 19:50, Paul Mira wrote:
> So thanks again everyone, I got a hunch from this Tom's advice Quote:
> <environments>
> <environment>
> <os>noenv</os>
> <ws>noenv</ws>
> <arch>noenv</arch>
> </environment>
> </environments>
> with this <environments>
> <environment>
> <os>win32</os>
> <ws>win32</ws>
> <arch>x86_64</arch>
> </environment>
> </environments>
> project) and replaced /noenv/noenv/noenv by /win32/win32/x86_64 in the
Previous Topic:JavaFX Codeeditors: Asciidoc demo?
Next Topic:Change in
Current Time: Fri Jul 25 07:32:40 EDT 2025
Powered by FUDForum. Page generated in 0.04763 seconds
