Hide pin/unpin tool in palette [message #1716970] |
Wed, 09 December 2015 05:40  |
Hi all,
can you please give me a hint how I can hide the pin/unpin button in the palette header?
I found the following which allows to hide standard tools from GEF/GMF, like zoom, notes and text elements:
<extension point="org.eclipse.gmf.runtime.diagram.ui.paletteProviders">
<paletteProvider class="org.eclipse.gmf.runtime.diagram.ui.providers.DefaultPaletteProvider">
<Priority name="High"/>
<contribution>
<predefinedEntry id="standardGroup/zoomTool" remove="true"/>
<predefinedEntry id="standardGroup/noteStack/noteTool" remove="true"/
<predefinedEntry id="standardGroup/noteStack/textTool" remove="true"/>
</contribution>
<editor id="org.eclipse.sirius.diagram.ui.part.SiriusDiagramEditorID"></editor>
</paletteProvider>
</extension>
Is a similar contribution possible for pin/unpin? If not which alternative approach is recommended?
TIA,
Axel
[Updated on: Wed, 09 December 2015 05:46] by Moderator
Re: Hide pin/unpin tool in palette [message #1717478 is a reply to message #1716970] |
Mon, 14 December 2015 05:10  |
On 12/09/2015 11:40 AM, Axel Guckelsberger wrote:
> Hi all,
Hi Axel,
There is no API to simply hide those actions. They are added in
org.eclipse.sirius.diagram.ui.tools.internal.palette.PaletteManagerImpl.addDefaultTools(Diagram)
and defined statically in
org.eclipse.sirius.diagram/model/DiagramEnvironment.odesign.
Florian
> palette header?
> <paletteProvider
> <contribution>
> remove="true"/
> remove="true"/>
> </contribution>
> <editor
> </paletteProvider>
> </extension>
> TIA,
> Axel
Florian - Obeo
FUDForum. Page generated in 0.04370 seconds
