Re: how to change location of just some file in p2 repository when materialize? [message #1717704 is a reply to message #1717356] |
Wed, 16 December 2015 02:22  |
On 12/12/2015 04:45, hiep lq wrote:
> (1) I have p2 repository for host zk-osgi at
> xxxx:##dl.bintray.com/hieplq/generic/zkossOSGiP2/8.0.0/
> (2) I have to change file zkbind by some reason. so i make new p2
> repository contain changed file at
> xxxx:##dl.bintray.com/hieplq/generic/modifyBundle/1.0.0/
> i want materialize all zk library from (1) and zk-bind from (2) so i
> have rmap as below
> <rm:locator pattern="^zkbind$" searchPathRef="modify.bundle" />
> <rm:locator pattern="^zcommon$" searchPathRef="zkoss.osgi" />
> <rm:locator pattern="^zel$" searchPathRef="zkoss.osgi" />
> <rm:locator pattern="^zhtml$" searchPathRef="zkoss.osgi" />
> <rm:locator pattern="^zk$" searchPathRef="zkoss.osgi" />
> <rm:locator pattern="^zkplus$" searchPathRef="zkoss.osgi" />
> <rm:locator pattern="^zul$" searchPathRef="zkoss.osgi" />
> <rm:locator pattern="^zweb$" searchPathRef="zkoss.osgi" />
> <rm:searchPath name="zkoss.osgi">
> <rm:provider componentTypes="osgi.bundle" readerType="p2">
> <rm:property key="buckminster.source" value="false" />
> <rm:property key="buckminster.mutable" value="false" />
> <rm:uri
> format="xxxx:##dl.bintray.com/hieplq/generic/zkossOSGiP2/8.0.0/" />
> </rm:provider>
> </rm:searchPath>
> <rm:searchPath name="modify.bundle">
> <rm:uri
> format="xxxx:##dl.bintray.com/hieplq/generic/modifyBundle/1.0.0/" />
> </rm:provider>
> </rm:searchPath>
> but when i materialize, zkbind always download from (1) ever when
> resolve it said modify.bundle is selected for zkbind.
> i guess buckminster priority for dependencies in same p2 repository than
> other.
> anyone can help me figure out solution?
> i have work-around by create other repository contain all bundle (modify
> and unmodify) xxxx:##dl.bintray.com/hieplq/generic/zkossOSGiP2/8.0.0.1/
> it work but isn't pretty good when i have many modify bundle of many
> difference repository.
> i use eclipse luna sp2 with buckminster 4.4
if I remember correctly, you can specify the two providers in the same
searchPath, and then put the modifyBundle repository *before* the other
one. The p2 repository should be consulted in the order they are
specified, and if something is not found in the first one it is searched
for in the second one.
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.07304 seconds
