Home » Modeling » Papyrus » Limitations in the size of Papyrus models
Limitations in the size of Papyrus models [message #1717053] |
Wed, 09 December 2015 13:02  |
we are managing a large model (about 6Mbyte) and after an impotant change we are no longer able to open it. With the previous version of the model, we noticed that the eclipse of heap reachesca. 750 Mbyte. The problem persists even with version 1.1.3 of Papyrus.
1) Is there a known maximum size in terms of number of the model items and/or size of the files for a correct usage of Papyrus? In such a case, a partitioning of the model (with the mechanism of the sub-models) could help?
2) Are there configurations of eclipse (eclipse.ini) that can help the manage of memory? Currently I have the following parameters:
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
--launcher.defaultAction
openFile
--launcher.appendVmargs
-vmargs
-Dosgi.requiredJavaVersion = 1.7
-Xms256m
-Xmx1024m
Any suggestions?
Thank you,
Nicola
Re: Limitations in the size of Papyrus models [message #1717198 is a reply to message #1717144] |
Thu, 10 December 2015 12:08   |
I have applied part of the suggested actions (increase memory resources, closing diagrams, etc.), but the result was not conclusive: after application of
repeatable changes (in general, new model items and filling of text in some properties of stereotypes), the model cannot be no longer opened if the files are NOT write-protected (for example, if the model files have been committed and made write-protected, the model can be opened!!!).
So, I tried to investigate more deeply launching Papyrus in debug mode, and I got the following message error (see below). After this error occurrence, no other model can be opened up to the restart of eclipse...
At this point I suspect that the problem may be related to a maximum size of the XML parser in the decoding phase and/or in the XML encoding when saving the model. Another possible issue is that the model tree is quite deep (up to 15 nested items)
What do you think?
Best Regards,
Nicola
!ENTRY org.eclipse.equinox.event 4 0 2015-12-10 17:38:58.522
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/SET] {NewValue=org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@142a721 (elementId: org.eclipse.e4.ui.compatibility.editor, tags: [Editor, org.eclipse.papyrus.infra.core.papyrusEditor, removeOnHide], contributorURI: null) (widget: ContributedPartRenderer$2 {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer@16a73c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor, object: null, context: PartImpl (org.eclipse.e4.ui.compatibility.editor) Context, variables: [], label: null, iconURI: null, tooltip: null, dirty: false, closeable: true, description: null), ChangedElement=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1e11910 (elementId: org.eclipse.e4.primaryDataStack, tags: [org.eclipse.e4.primaryDataStack, EditorStack], contributorURI: null) (widget: CTabFolder {}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@1cd1d3c, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), EventType=SET, AttName=selectedElement, Widget=CTabFolder {}} to handler org.eclipse.e4.ui.services.internal.events.UIEventHandler@5effa2
!STACK 0
java.lang.OutOfMemoryError: Java heap space
at com.sun.org.apache.xerces.internal.util.XMLStringBuffer.append(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.scanAttributeValue(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanAttribute(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.papyrus.infra.core.resource.ModelSet.demandLoad(ModelSet.java:380)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.papyrus.infra.core.resource.ModelSet.getResource(ModelSet.java:221)
at org.eclipse.papyrus.infra.core.resource.AbstractBaseModel.loadModel(AbstractBaseModel.java:184)
at org.eclipse.papyrus.infra.core.resource.ModelSet.loadModels(ModelSet.java:584)
at org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.loadModelAndServices(CoreMultiDiagramEditor.java:616)
at org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.initContents(CoreMultiDiagramEditor.java:921)
at org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.init(CoreMultiDiagramEditor.java:489)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:361)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:319)
Re: Limitations in the size of Papyrus models [message #1717301 is a reply to message #1717198] |
Fri, 11 December 2015 08:30   |
Hi, Nicola,
No, the out-of-memory condition is rarely traceable so directly to the
root cause. When the heap runs out, whatever code is the next to
request an allocation of memory, doing anything at all on any thread,
will have an OutOfMemoryError thrown at it by the JVM. The code that
runs into this error has nothing to do with the reasons why the heap
was exhausted.
And, yes, out-of-memory is a fatal condition that requires the JVM to
shut down. There is no possible recovery because any code anywhere can
just fail unexpectedly at any time.
Christian
On 2015-12-10 17:08:04 +0000, Nicola Mazzacane said:
> after application of repeatable changes (in general, new model items
> What do you think?
> Best Regards,
> Nicola
> {NewValue=mailto:org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@142a721
> mailto:org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer@16a73c,
> description: null),
> ChangedElement=mailto:org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@1e11910
> mailto:org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@1cd1d3c,
> mailto:org.eclipse.e4.ui.services.internal.events.UIEventHandler@5effa2
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FIXED: Limitations in the size of Papyrus models [message #1718415 is a reply to message #1717301] |
Wed, 23 December 2015 08:41  |
Hi Christian,
we have solved the problem, which actually was related to a maximum size of the XML parser.
The model has been populated automatically parsing a Word document. When extracting one string, I introduced in a text field of a stereotype the following 20 special characters (in hex):
90 b7 f0 f0 9d 9d 9d 91 91 8e f0 f0 9d a1 e2 88 99 91 8e
After saving the model, the text field of a stereotype in the file * .uml becomed unusually long, because the above character sequence is repeated several times, creating a string of more 143000 characters.
Nicola
Current Time: Sat Jul 26 23:31:08 EDT 2025
Powered by FUDForum. Page generated in 0.04058 seconds
