How do I remove columns after I've created TableViewer? [message #550338] |
Thu, 29 July 2010 19:35  |
I have an RCP app using an EMF model running on Galileo. I have a View open in a perspective, when a user opens the XMI file for the model I want the View's TableViewer to be updated. The number of columns can vary, is the only thing. With each model that the user opens, the number of columns may change.
What is the proper way to accomplish this? I have been looking all over and I've tried a lot of things (to the point of confusion).
Thanks in advance,
Jon
Re: How do I remove columns after I've created TableViewer? [message #550635 is a reply to message #550338] |
Tue, 03 August 2010 19:45   |
Thanks! I have tried that, but I have this problem where no matter how I try to remove all the columns, 1 or more remain.
For example, when I do the following:
TableColumn[] columns = table.getColumns() ;
for( TableColumn tc : columns ) {
tc.dispose() ;
I have 1 column left over with no header, just the data. Additionally, from the behavior it appears it starts with the last column and works backwards toward the first (right to left).
When I try this:
int x = table.getColumnCount() ;
for( int y=0 ; y<x; y++ ) {
table.getColumn(y).dispose() ;
It gives me an IndexOutOfBoundsException after the second (of four) column. Then if I get the count again, it says there are still two columns left and if I do another loop it will blow up after the first column - and again if I call table.getColumnCount() it says 1 is left, which I can dispose of but still there is 1 column of data visible. Very strange.
Finally, if I do this:
for( int y=x-1; y>-1; y-- ) {
It leaves me with 1 column of data (the first one) with no header.
I thought it might have to do with the indexing starting at 1 instead of 0 but it appears that the columns are zero based, so I don't think this is it either. If I change that last for loop to let y become negative it blows up.
Clearly I am doing something wrong. Any pointers will be gratefully accepted!
Re: How do I remove columns after I've created TableViewer? [message #550719 is a reply to message #550635] |
Wed, 04 August 2010 04:15   |
The problem you have is that a table without a column is a legal construct.
Am 04.08.10 01:45, schrieb Jon Svede:
> tc.dispose() ;
That's correct.
> When I try this:
If you think about this you should grasp why this is not working and
giving you exceptions, right?
> Very strange.
> it blows up.
> accepted!
You are not - as outlined in my first paragraph a Table without columns
is perfectly legal construct at the very moment you'll add one new
column the single one vanishes.
Beside that as outlined also in my initial response if you are removing
all columns anyways it's a lot better to dispose the complete Table and
recreate it from scratch.
Tom
Re: How do I remove columns after I've created TableViewer? [message #550847 is a reply to message #550719] |
Wed, 04 August 2010 09:46   |
Thanks, Tom.
My conclusion is that the number of columns diminishes while the index of the for loop grows. After disposing 2 columns the loop is looking to get the column at index=2 or column 3 which is beyond the size of the current column array. In all seriousness, thanks for making me think about it rather than just giving it up.
I'm obviously being obtuse because I can't seem to make that work (though I like that idea, it's cleaner).
I have an IPartListener listening for the close event from an editor. When I receive that event from the particular editor, I've tried the following:
tableViewer.getTable().dispose() ; // this causes issues
Instead, I've tried this:
Table table = tableViewer.getTable() ;
table.dispose() ;
table = new Table( tableViewer.getControl().getParent(), SWT.NONE) ;
That doesn't work, but I think that it's related to the getControl() call since the underlying control has been disposed.
I've also tried caching the original Composite as a member variable and using it to re-create the TableViewer, but that doesn't seem to work either (though it doesn't throw any exceptions).
Any suggestions?
Jon
FUDForum. Page generated in 0.07213 seconds
