Home » Archived » Eclipse Process Manager (Stardust) » Copy Model Not Working - Attached Models For reference(Copy Model Not Working - Attached Models For reference)
Copy Model Not Working - Attached Models For reference [message #1717190] Thu, 10 December 2015 10:51 Go to next message
I am having a model. Which having Three Processes
Model1
-ProcessA
-ProcessB
-ProcessC
ProcessA is starting the ProcessB and ProcessC as part of its functionality by using process:start command.
Model1 deployed and is working perfectly fine no issues everything is well.
Now I copied the Model1 and Created Model2 so my model2 is like this
Model2
-ProcessA
-ProcessB
-ProcessC
I opened the XPDL of copied model i.e. Model2 - changed the ID and Name to Model2 also changed the process Names which auto changed the ID's of process so now I have like this.
Model2
-WProcessA
-WProcessB
-WProcessC
I changed the process:start command for new process Name for model2
Now I deployed the both the models.
I executed processA of Model1 which internally call ProcessB completed it successfully.
Now I tried executing WProcessA of Model2 which internally calls WProcessB and it failed can not find a process with process name WProcessB
Now I redeployed only Model2 and executed WprocessA of Model2 which internally call WProcessB and completed it successfully.
but executing processA of Model1 which internally call ProcessB failed saying can not find a process with process name ProcessB
SO, My Problem is I copied from Model1 to Model2. But Looks like the model2 internally maintaining the connection with Model1 processes and when I deploy model1 it overwrite the model2 process. and when i deploy model2 it overwrite model1 processes.
Any Idea, solution, Thoughts on above problem statement
Attached Models For Reference
Thanks in advance.
[Updated on: Fri, 11 December 2015 00:38] by Moderator
Re: Copy Model Not Working - Attached Models For reference [message #1717261 is a reply to message #1717190] Fri, 11 December 2015 03:24 Go to previous message
The Error I am getting
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor$1.doInTransaction(SpringTxInterceptor.java:93)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:131)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor.invoke(SpringTxInterceptor.java:71)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.proceed(MethodInvocationImpl.java:130)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.execute(MethodInvocationImpl.java:68)
at org.eclipse.stardust.engine.core.runtime.beans.InvocationManager.invoke(InvocationManager.java:53)
at com.sun.proxy.$Proxy60.execute(Unknown Source)
at org.eclipse.stardust.engine.api.spring.WorkflowServiceBean.execute(WorkflowServiceBean.java:885)
at sun.reflect.GeneratedMethodAccessor1179.invoke(Unknown Source)
at org.eclipse.stardust.engine.api.spring.SpringServiceFactory$SpringServiceInvocationHandler.invoke(SpringServiceFactory.java:185)
at org.eclipse.stardust.engine.extensions.camel.component.process.subcommand.StartProcessSubCommand.process(StartProcessSubCommand.java:47)
at org.eclipse.stardust.engine.extensions.camel.component.ProcessProducer.process(ProcessProducer.java:80)
at org.apache.camel.util.AsyncProcessorConverterHelper$ProcessorToAsyncProcessorBridge.process(AsyncProcessorConverterHelper.java:61)
at org.apache.camel.processor.SendProcessor.process(SendProcessor.java:120)
at org.apache.camel.management.InstrumentationProcessor.process(InstrumentationProcessor.java:72)
at org.apache.camel.processor.interceptor.TraceInterceptor.process(TraceInterceptor.java:163)
at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:398)
at org.apache.camel.util.AsyncProcessorHelper.process(AsyncProcessorHelper.java:105)
at org.apache.camel.processor.RedeliveryErrorHandler.process(RedeliveryErrorHandler.java:279)
at org.apache.camel.processor.DefaultErrorHandler.process(DefaultErrorHandler.java:56)
at org.apache.camel.processor.CamelInternalProcessor.process(CamelInternalProcessor.java:166)
at org.apache.camel.processor.Pipeline.process(Pipeline.java:118)
at org.apache.camel.processor.Pipeline.process(Pipeline.java:80)
at org.apache.camel.spring.spi.TransactionErrorHandler.processByErrorHandler(TransactionErrorHandler.java:218)
at org.apache.camel.spring.spi.TransactionErrorHandler.process(TransactionErrorHandler.java:99)
at org.apache.camel.spring.spi.TransactionErrorHandler.process(TransactionErrorHandler.java:112)
at org.apache.camel.spring.spi.TransactionErrorHandler$1.doInTransactionWithoutResult(TransactionErrorHandler.java:181)
at org.springframework.transaction.support.TransactionCallbackWithoutResult.doInTransaction(TransactionCallbackWithoutResult.java:33)
at org.apache.camel.spring.spi.TransactionErrorHandler.doInTransactionTemplate(TransactionErrorHandler.java:174)
at org.apache.camel.spring.spi.TransactionErrorHandler.processInTransaction(TransactionErrorHandler.java:134)
at org.apache.camel.spring.spi.TransactionErrorHandler.process(TransactionErrorHandler.java:103)
at org.apache.camel.processor.CamelInternalProcessor.process(CamelInternalProcessor.java:191)
at org.apache.camel.component.direct.DirectProducer.process(DirectProducer.java:51)
at org.apache.camel.processor.UnitOfWorkProducer.process(UnitOfWorkProducer.java:74)
at org.apache.camel.impl.ProducerCache$2.doInProducer(ProducerCache.java:375)
at org.apache.camel.impl.ProducerCache$2.doInProducer(ProducerCache.java:343)
at org.apache.camel.impl.ProducerCache.doInProducer(ProducerCache.java:233)
at org.apache.camel.impl.ProducerCache.sendExchange(ProducerCache.java:343)
at org.apache.camel.impl.ProducerCache.send(ProducerCache.java:168)
at org.apache.camel.impl.DefaultProducerTemplate.send(DefaultProducerTemplate.java:119)
at org.apache.camel.impl.DefaultProducerTemplate.send(DefaultProducerTemplate.java:105)
at org.eclipse.stardust.engine.extensions.camel.GenericProducer.sendMessage(GenericProducer.java:189)
at org.eclipse.stardust.engine.extensions.camel.GenericProducer.sendBodyInOut(GenericProducer.java:178)
at org.eclipse.stardust.engine.extensions.camel.app.CamelProducerSpringBeanApplicationInstance.invoke(CamelProducerSpringBeanApplicationInstance.java:131)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.retrySynchronousApplication(ActivityInstanceBean.java:1626)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1552)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1368)
... 129 more
Caused by: org.eclipse.stardust.common.error.ObjectNotFoundException: MDL_01102 - Cannot find process definition 'WProcessB'.: WProcessB
at org.eclipse.stardust.engine.core.runtime.beans.QueryServiceImpl.getProcessDefinition(QueryServiceImpl.java:680)
at org.eclipse.stardust.engine.core.runtime.beans.QueryServiceImpl.getProcessDefinition(QueryServiceImpl.java:665)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CallingInterceptor.invoke(CallingInterceptor.java:29)
at org.eclipse.stardust.engine.core.runtime.beans.EmbeddedServiceFactory$ExceptionHandlingInterceptor.invoke(EmbeddedServiceFactory.java:207)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.RuntimeExtensionsInterceptor.invoke(RuntimeExtensionsInterceptor.java:34)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.GuardingInterceptor.invoke(GuardingInterceptor.java:55)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CurrentUserInterceptor.invoke(CurrentUserInterceptor.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.EmbeddedServiceFactory$FlushInterceptor.invoke(EmbeddedServiceFactory.java:190)
at com.sun.proxy.$Proxy62.getProcessDefinition(Unknown Source)
at org.eclipse.stardust.engine.extensions.camel.component.process.subcommand.StartProcessAndAttachDocumentCommand.execute(StartProcessAndAttachDocumentCommand.java:46)
at org.eclipse.stardust.engine.extensions.camel.component.process.subcommand.StartProcessAndAttachDocumentCommand.execute(StartProcessAndAttachDocumentCommand.java:24)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.execute(WorkflowServiceImpl.java:2256)
... 219 more
10:17:24 WARN [080-exec-8] LogUtils -
org.eclipse.stardust.engine.core.runtime.beans.NonInteractiveApplicationException: Exception occured for noninteractive activity 115. Message was: MDL_01102 - Cannot find process definition 'WProcessB'.: MDL_01102 - Cannot find process definition 'WProcessB'.: WProcessB
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1385)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invoke(ActivityInstanceBean.java:1154)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.doStartActivity(ActivityInstanceBean.java:1144)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.start(ActivityInstanceBean.java:1105)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.runCurrentActivity(ActivityThread.java:1123)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.run(ActivityThread.java:365)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.schedule(ActivityThread.java:126)
at org.eclipse.stardust.engine.core.runtime.audittrail.management.ActivityInstanceUtils.complete(ActivityInstanceUtils.java:407)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:892)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:779)
at sun.reflect.GeneratedMethodAccessor1178.invoke(Unknown Source)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.POJOExceptionHandler.invoke(POJOExceptionHandler.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.performCall(AbstractLoginInterceptor.java:202)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.invoke(AbstractLoginInterceptor.java:132)
at org.eclipse.stardust.engine.api.spring.SpringBeanLoginInterceptor.invoke(SpringBeanLoginInterceptor.java:79)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.doWithDataSource(SpringSessionInterceptor.java:142)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.access$000(SpringSessionInterceptor.java:48)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor$1.doInConnection(SpringSessionInterceptor.java:87)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:342)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.invoke(SpringSessionInterceptor.java:81)
at org.eclipse.stardust.engine.api.spring.SpringConfigurationInterceptor.invoke(SpringConfigurationInterceptor.java:101)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.PropertyLayerProviderInterceptor.invoke(PropertyLayerProviderInterceptor.java:129)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.invoke(DebugInterceptor.java:56)
at com.sun.proxy.$Proxy60.complete(Unknown Source)
at org.eclipse.stardust.engine.api.spring.WorkflowServiceBean.complete(WorkflowServiceBean.java:68)
at org.eclipse.stardust.ui.web.processportal.common.PPUtils.complete(PPUtils.java:462)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivityContinue(ActivityDetailsBean.java:1863)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.access$1100(ActivityDetailsBean.java:143)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean$7.handleEvent(ActivityDetailsBean.java:1840)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMappingContinue(ActivityDetailsBean.java:2157)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMapping(ActivityDetailsBean.java:2138)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1825)
at org.eclipse.stardust.ui.web.processportal.view.ActivityPanelController.setRemoteControlActivityStateChangeCommandId(ActivityPanelController.java:194)
at sun.reflect.GeneratedMethodAccessor1177.invoke(Unknown Source)
at org.apache.myfaces.el.PropertyResolverImpl.setProperty(PropertyResolverImpl.java:409)
at org.apache.myfaces.el.PropertyResolverImpl.setValue(PropertyResolverImpl.java:176)
at com.sun.facelets.el.LegacyELContext$LegacyELResolver.setValue(LegacyELContext.java:201)
at com.sun.el.parser.AstValue.setValue(AstValue.java:113)
at com.sun.el.ValueExpressionImpl.setValue(ValueExpressionImpl.java:246)
at com.sun.facelets.el.TagValueExpression.setValue(TagValueExpression.java:93)
at com.sun.facelets.el.LegacyValueBinding.setValue(LegacyValueBinding.java:68)
at javax.faces.component.UIInput.updateModel(UIInput.java:270)
at javax.faces.component.UIInput.processUpdates(UIInput.java:207)
at javax.faces.component.UIComponentBase.processUpdates(UIComponentBase.java:648)
at org.eclipse.stardust.ui.web.common.app.tags.TabScopedComponent.processUpdates(TabScopedComponent.java:128)
at javax.faces.component.UIForm.processUpdates(UIForm.java:90)
at javax.faces.component.UIViewRoot.processUpdates(UIViewRoot.java:160)
at org.apache.myfaces.lifecycle.UpdateModelValuesExecutor.execute(UpdateModelValuesExecutor.java:33)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:95)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:70)
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:50)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:169)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:110)
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:65)
at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:51)
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:62)
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55)
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:107)
at com.icesoft.faces.webapp.http.servlet.BlockExpiredSessionRequests.service(BlockExpiredSessionRequests.java:53)
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:204)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:71)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.eclipse.stardust.ui.web.html5.EnhancedJarResourceFilter.doFilter(EnhancedJarResourceFilter.java:140)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:100)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:603)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: org.eclipse.stardust.common.error.ServiceCommandException: MDL_01102 - Cannot find process definition 'WProcessB'.: MDL_01102 - Cannot find process definition 'WProcessB'.: WProcessB
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.execute(WorkflowServiceImpl.java:2276)
... 129 more
... 219 more
org.eclipse.stardust.common.error.InternalException: Unexpected activity thread state.
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.run(ActivityThread.java:403)
10:17:24 WARN [080-exec-8] Transaction - Error ending association for XAResource org.apache.geronimo.transaction.manager.WrapperNamedXAResource@6ab9ce6f; transaction will roll back. XA error code: 100
javax.transaction.xa.XAException
at org.apache.derby.jdbc.EmbedXAResource.end(Unknown Source)
at org.apache.geronimo.transaction.manager.WrapperNamedXAResource.end(WrapperNamedXAResource.java:61)
at org.apache.geronimo.transaction.manager.TransactionImpl.endResources(TransactionImpl.java:569)
at org.apache.geronimo.transaction.manager.TransactionImpl.endResources(TransactionImpl.java:548)
at org.apache.geronimo.transaction.manager.TransactionImpl.rollback(TransactionImpl.java:488)
at org.apache.geronimo.transaction.manager.TransactionManagerImpl.rollback(TransactionManagerImpl.java:265)
at org.springframework.transaction.jta.JtaTransactionManager.doRollback(JtaTransactionManager.java:1038)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processRollback(AbstractPlatformTransactionManager.java:846)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.rollback(AbstractPlatformTransactionManager.java:823)
at org.springframework.transaction.support.TransactionTemplate.rollbackOnException(TransactionTemplate.java:162)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:135)
10:17:24 ERROR [080-exec-8] ExceptionHandler -
Previous Topic:Getting data sets and sql from a report
Next Topic:How to copy and input common data to various SOAP based web-services in a Process
Current Time: Sun Jul 20 21:18:42 EDT 2025
Powered by FUDForum. Page generated in 0.47417 seconds
