Home » Archived » Hudson » Hudson slave on Windows use a bad path for maven
Hudson slave on Windows use a bad path for maven [message #1715121] Thu, 19 November 2015 06:55 Go to next message
We have a Hudson-master (3.3.2) on Linux, with Maven3-plugin (3.0.5).
Furthermore we use a Hudson-slave of this master on Windows.
In the master configuration there I defined the Linux-path to Maven (3.0.5).
In the node configuartion for this slave there I defined the path to Maven (3.0.5) for the Windows-slave. (d:\...\apache-maven-3.0.5).
We use a jdk 1.7.0.
In jobs I use the Maven3 plugin with a reference to apache-maven-3.0.5.
Jobs on the master havn´t problems.
But jobs on the slave fail because the plugin use the Linux-Path (/home/.../apache-maven-3.0.5) to apache-maven-3.0.5 and not the Windows-path from the configuraton for the slave node.
Has anyone an idea?
Elko
[Updated on: Thu, 19 November 2015 06:57] by Moderator
Re: Hudson slave on Windows use a bad path for maven [message #1715167 is a reply to message #1715121] Thu, 19 November 2015 13:14 Go to previous messageGo to next message
Hmm.. that is strange. The plugin is supposed to use the exact path defined in the tools section of the slave configuration. Can you please file a bug at https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Hudson (Use components Plugins). We will try to reproduce and fix.
Re: Hudson slave on Windows use a bad path for maven [message #1717133 is a reply to message #1715167] Thu, 10 December 2015 03:19 Go to previous message
Okay. Thanks.
Elko
[Updated on: Thu, 10 December 2015 03:20] by Moderator
Previous Topic:Missing Jobs after Downgrade
Next Topic:Hudson problem after interuption on slave
Current Time: Sun Jul 27 02:29:11 EDT 2025
Powered by FUDForum. Page generated in 0.02873 seconds
