Home » Modeling » EMF » [CDO] Transaction Notification Issue
[CDO] Transaction Notification Issue [message #1714372] Thu, 12 November 2015 04:22 Go to next message
We encountered an issue with the notifications of transactions,
Some Clients are connected to the CDO Server, and every Client does some stuff like opening/closing transactions, reading and writing from and to the server.
The Server recieves around 30 commits/sec, sometimes more, sometimes less. Everything is ok performance-wise.
If another Client connects to the Server it *may* happen after some time that the client gets in a state where the
waitForUpdate(timeStamp, 10000);
in
CDOTransactionImpl.commit
*always* gets a timeout on every commit. Because of this, every commit runs for at least 10 seconds. The Data however is commited instantly, and every other client gets an appropriate notification.
We suspected some Performance Issue at this point, but on further inspection in turnes out that this client gets no notifications whatsoever.
Closing the session and transaction and recreating them has no effect, only restarting the client completely works (until it happens again).
We use CDO 4.4, and the Clients connect with a ReconnectingSessionConfiguration. The transactions have the options
    transaction.options().addChangeSubscriptionPolicy(CDOAdapterPolicy.ALL);
    transaction.options().setInvalidationNotificationEnabled(true);
Greetings,
Samuel
Re: [CDO] Transaction Notification Issue [message #1717107 is a reply to message #1714372] Wed, 09 December 2015 17:43 Go to previous message
Hi Samuel,
I figured out this issue:
In my case, it only happens when you perform a commit within a CDO invalidation notification i.e your transaction is updating with remote changes (commit from a remote client i.e another JVM) and due to the change policy you set to ALL , it can notify eAdapters registered on your CDO Objects that leads to another commit.
To avoid the waitForUpdate(10s) you need to post the eAdapters() implementation that leads to another commit on another thread not the CDOInvalidationOne.
Hope it helps.
Samuel Leisering wrote on Thu, 12 November 2015 04:22
in
Greetings,
Samuel
Previous Topic:Serializing EMF objects to StringBuffer
Next Topic:EMF parsed xml file skips xml stylesheet tag
Current Time: Wed Jul 23 16:19:16 EDT 2025
Powered by FUDForum. Page generated in 0.04063 seconds
