Home » Eclipse Projects » Kura » ConfigurableExample service isn't showed in Kura Web UI
ConfigurableExample service isn't showed in Kura Web UI [message #1716588] Sat, 05 December 2015 10:36 Go to next message
I followed the hello example from the Kura documentation and it seems to work fine.
I followed the configurable example but I'm in troubles.
The configurable example service isn't showed in the Kura services Web UI.
The strange thing is that I can see the bundle in the Active state (from Device -> Bundles menu) but I can't see in the console the message printed by the logger instance as provided by the class implementation.
So ... the bundle is active but the active() method isn't executed ?
I'm using the emulator.
The active() method of hello example works fine.
I can't see any error.
What's the problem ?
Paolo.
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1716707 is a reply to message #1716588] Mon, 07 December 2015 11:16 Go to previous messageGo to next message
Hi Paolo,
If you are running the emulator, please go to the Eclipse IDE Console window and press 'enter'. This should bring up an 'osgi>' prompt. From the prompt enter the 'ls' command and paste the results to the forum. We need to make sure your configurable example is satisfied and being exposed as a service.
--Dave
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1716733 is a reply to message #1716707] Mon, 07 December 2015 15:42 Go to previous messageGo to next message
Hi Dave,
thanks for your reply. I noticed the following ...
If the configuration policy of the ConfigurableExample is set to "require" as documentation describes, this is the output of "ls" command.
As you can see the service is in the list with Unsatisfied state.
ID State Component Name Located in bundle
1 Unsatisfied org.eclipse.kura.example.configurable org.eclipse.kura.example.configurable(bid=1)
2 Active org.eclipse.kura.deployment.agent org.eclipse.kura.deployment.agent(bid=2)
3 Active org.eclipse.kura.data.DataService org.eclipse.kura.core(bid=4)
4 Active org.eclipse.kura.db.DbService org.eclipse.kura.core(bid=4)
5 Active org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport org.eclipse.kura.core(bid=4)
6 Active org.eclipse.kura.ssl.SslManagerService org.eclipse.kura.core(bid=4)
7 Active org.eclipse.kura.system.SystemService org.eclipse.kura.core(bid=4)
8 Active org.eclipse.kura.system.SystemAdminService org.eclipse.kura.core(bid=4)
9 Active org.eclipse.kura.emulator.Emulator org.eclipse.kura.emulator(bid=9)
10 Active org.eclipse.kura.watchdog.WatchdogService org.eclipse.kura.emulator(bid=9)
11 Active org.eclipse.kura.position.PositionService org.eclipse.kura.emulator(bid=9)
12 Active org.eclipse.kura.clock.ClockService org.eclipse.kura.emulator(bid=9)
13 Active org.eclipse.kura.net.NetworkService org.eclipse.kura.emulator(bid=9)
14 Active org.eclipse.kura.usb.UsbService org.eclipse.kura.emulator(bid=9)
15 Active org.eclipse.kura.cloud.CloudService org.eclipse.kura.core.cloud(bid=11)
16 Active org.eclipse.kura.cloud.CloudCallService org.eclipse.kura.core.cloud(bid=11)
17 Active org.eclipse.kura.cloud.app.command.CommandCloudApp org.eclipse.kura.core.cloud(bid=11)
18 Active org.eclipse.kura.web.Console org.eclipse.kura.web(bid=14)
19 Active org.eclipse.kura.configuration.ConfigurationService org.eclipse.kura.core.configuration(bid=15)
20 Active org.eclipse.kura.status.CloudConnectionStatusService org.eclipse.kura.linux.status(bid=23)
21 Active org.eclipse.kura.certificate.CertificatesService org.eclipse.kura.core.certificates(bid=36)
22 Active org.eclipse.equinox.event org.eclipse.equinox.event(bid=38)
23 Active org.eclipse.kura.crypto.CryptoService org.eclipse.kura.core.crypto(bid=49)
24 Active org.eclipse.kura.gpio.GPIOService org.eclipse.kura.emulator.gpio(bid=50)
25 Active org.eclipse.kura.core.comm.CommConnectionFactory org.eclipse.kura.core.comm(bid=51)
26 Active org.eclipse.kura.example.hello_osgi org.eclipse.kura.example.hello_osgi(bid=53)
27 Active org.eclipse.kura.demo.heater.Heater org.eclipse.kura.demo.heater(bid=54)
If I leave empty the configuration policy in the component.xml, the ConfigurableExample is activated as you can see (Active state) :
All Components:
1 Active org.eclipse.kura.example.configurable org.eclipse.kura.example.configurable(bid=1)
However in both cases it doesn't appear in the Kura Web UI.
Any idea ?
Paolo.
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1716876 is a reply to message #1716733] Tue, 08 December 2015 12:56 Go to previous messageGo to next message
Hi Paolo,
For this you want the configuration policy to be "required". The issue appears that ConfigurationAdmin can't find your metatype XML. Did you create all the directories and xml files from the tutorial in your bundle? It should look something like:
/META-INF
/META-INF/MANIFEST.MF
/OSGI-INF
/OSGI-INF/metatype
/OSGI-INF/metatype/org.eclipse.kura.example.configurable.ConfigurableExample.xml
/OSGI-INF/component.xml
The step about including the OSGI-INF directory in your build.xml file is also very important. You should be able to compare your example with the org.eclipse.kura.example.heater project. The two setups should be nearly identical except for the namespace.
--Dave
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1716878 is a reply to message #1716876] Tue, 08 December 2015 12:58 Go to previous messageGo to next message
It's what I have done. It seems that the two projects are identical Sad
For this reason it's driving me crazy !
I can't find a reason why ConfigurableExample doesn't work properly.
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1716881 is a reply to message #1716878] Tue, 08 December 2015 13:21 Go to previous messageGo to next message
Hi Paolo,
It is almost certainly a typo somewhere. Can you attach your XML files or, preferably, send a link to a Github site with your source files?
--Dave
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1716885 is a reply to message #1716881] Tue, 08 December 2015 14:24 Go to previous messageGo to next message
For sure ... I agree with you ... there is something I'm missing.
Attached the XML files and the manifest.
Thanks for your help.
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1716996 is a reply to message #1716885] Wed, 09 December 2015 09:07 Go to previous messageGo to next message
Please make sure that your packaged bundle actually contains the resources in the OSGI-INF folder.
Your build.properties should contain a bin.includes entry along the lines of:
bin.includes = META-INF/,\
               OSGI-INF/
[Updated on: Wed, 09 December 2015 09:07] by Moderator
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1717004 is a reply to message #1716996] Wed, 09 December 2015 10:00 Go to previous messageGo to next message
The build.properties is the following :
output.. = bin/
               OSGI-INF/
source.. = src/
additional.bundles = org.eclipse.osgi.services,\
                     slf4j.api,\
                     org.eclipse.kura.api
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1717013 is a reply to message #1716733] Wed, 09 December 2015 10:23 Go to previous messageGo to next message
Paolo Patierno wrote on Mon, 07 December 2015 21:42
Hi Dave,
typing comp 1 (or whichever is the ID of the bogus component) may give you more hints on what's actually wrong.
I would suggest you do as Dave said and provide us with a link to a git repo with the full code, as that may help tremendously narrow down the problem.
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1717021 is a reply to message #1717013] Wed, 09 December 2015 11:00 Go to previous messageGo to next message
I have just created a temporary GitHub project :
https://github.com/ppatierno/kura_temp/tree/master/org.eclipse.kura.example.configurable
Thank you very much for your help !
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1717520 is a reply to message #1717021] Mon, 14 December 2015 09:27 Go to previous messageGo to next message
Hi Paolo,
I was able to get your example running. It is a simple typo, but probably not well described in the tutorial. The issue is in the 'name' field of your component.xml file. The 'name' field must match the id specified in the configuration file. You 'name' field was set to:
It should be set to:
I think if you make this change, the example should work for you.
--Dave
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1717534 is a reply to message #1717520] Mon, 14 December 2015 10:32 Go to previous messageGo to next message
Now it works !
Thank you very much David Wink
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1721685 is a reply to message #1717520] Fri, 29 January 2016 03:11 Go to previous messageGo to next message
Hi Dave,
I have the same problem with Paolo ( can't show this example on GUI web kura)
But my component.xml still right name as your said.
here is my code on github:
https://github.com/hptphuong/IOT_Gateway/tree/master/org.eclipse.kura.example.configurable
Please help me solve it.
Thank a lot
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1721835 is a reply to message #1721685] Sun, 31 January 2016 16:49 Go to previous messageGo to next message
The project looks ok. Can you please use the OSGi console and provide the output of these two commands:
ss
ls
--Dave
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1721846 is a reply to message #1721835] Sun, 31 January 2016 22:26 Go to previous messageGo to next message
Thank Dave,
I found out what is the problems.
I try to save component.xml with:
-Configuration policy: require
- Check box option: This component is enabled when started & This component is immedieately actived.
But it's not really save to my component.xml.
I try to re-saved it again. And it's ok.
Thank you very much, Dave.
Re: ConfigurableExample service isn't showed in Kura Web UI [message #1782637 is a reply to message #1716588] Tue, 27 February 2018 05:07 Go to previous message
Hi guys,
I have the same issue,
I installed the package following the configurable example in the documentation but nothing appeared in my Wed UI.
Previous Topic:Kura Username/Password Change
Next Topic:I can't import JDK.dio to my project
Current Time: Sun Jul 20 18:52:35 EDT 2025
Powered by FUDForum. Page generated in 0.06002 seconds
